I need an answer to a question!!!
Discussion in 'The Garage' started by joshuav, Aug 30, 2005.
  1. joshuav
    joshuav Newbie
    Aug 30, 2005
    3
    sacramento
    I just got a 1985 k-5 blazer and when I acell it makes a knock knock noise then once I get up too speed the noise goes away. I just checked the pumpkin and all the rear end gears are fine. What else could it be?
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,851
    280
    Truckee, CA
    could it be the motor pinging?
    I always thought i had a bad ujoint or somethign until a mechanic said the timing was off and the sound was hte motor pinging.
    Run your tank almost empty, and put 1/2 a tank of premium in and see if the problem goes away.
    If it does, then get your timing adjusted so it won't ping on regular gas.
  3. joshuav
    joshuav Newbie
    Aug 30, 2005
    3
    sacramento
    I have not tryed that. Do you really think all of that metal klunking noise could be from that?
  4. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    cracked flexplate will "knock" under load also. you can see it with a flashlight after pulling trans dust cover, look near the crank flange
    just a thought
    (BTW auto tranny only)
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Its not an engine knock is it? Thats bad news. If it goes away when you let off tho it probably isn't.
  6. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    If you have a slight shudder also....you may consider a bad tranny mount..
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Could be the t-case contacting the floor , like it does in my truck due to soft mounts.
  8. dyeager535
    26,975
    I second the flexplate issue.
    Experience I had with one was pretty similar. Any time the engine was under load (accelerating from stop, starting at bottom of hill and trying to accelerate even slowly) there would be a quite audible knock.
    It's a pretty common problem on all GM vehicles, at least the gen1 SBC.
