I need BIG block advice
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by simply_signs, Aug 24, 2003.
  1. simply_signs
    simply_signs Registered Member
    May 30, 2003
    9
    I am building a 78 Blazer and I want a BIG block with some tork. I have options to buy a 402, 454 or 502. All are long blocks and are mostly stock. Never been rebuilt. And all still run. I would like to no which has more tork?
    My 78 has 44's (boggers), 400/205, 5:13 gears (locked). This will NOT be a everyday driver. Just for play!!! /forums/images/graemlins/usaflag.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    No substitute for CUBIC inches, when in doubt bore it out. The 502 stock will have more than the 402 or 454.
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    i have to agree. 502, 454 at a minimum(splg).
  4. the professor
    the professor 1/2 ton status
    Feb 6, 2003
    130
    THe 402 is an "emissions" motor, basicly a lo-compression slightly overbore 396
    The 502 is a "new-design" motor, with some changes like the rear main and the way the valve covers mount..
    AND it has roller lifters..and "round-port-heads" (I think they are the same as the 'small-oval-port" but I could be wrong...
    The easiest will be the 7.4L/454.. cheaper, usualy
    BUUUT... if you want the best torque from a 454, you need the 1988 or later motor..
    That motor is a "small-oval-port" motor, it has "guide-plates" for the pushrods and some other small improvements to the heads..again, similar to the 502
    Most notibly it produces MORE torque and HP, than the earlier oval-port 454 engine...and does so on just about any cheap gas you can find without any pinging...
    It has to do with the combustion chamber and port design, which is similar to the 502
    Ultimately the 502 will produce the most, torque and hp...
    Forget the 402, use the SB 400.. the 402 doesn't make enough torque and HP to make up for the increase in weight and parts cost...
    "earlier" 454's would be "ok", but they I would say for sure go with the 502
    One thing.. be sure you driveline is up to a 7.4 or even more so a 502.. These puppies produce ALOT of torque and WILL break things..
    For general usage, you can run a TH700 or 350 / 208 behind a relatively "stock" 454,(I do, did)as long as its properly built and in good condition, but you might have problems with a 502..
    For your use you will probably need a modified TH400, I say "modified" because even a TH400 being used the way you are using it may have problems if not in the best of condition...
    Make sure you got a "big" Torque Converter, the "small" torque converter usualy used behind a SB will generate WAY too much heat.../forums/images/graemlins/cool.gif
    Oh yea, I have a 1989 454HO,4-bolt crate motor in my 1978-K20 -700r4/208 now, and have used TH350 and TH700/ NP205 in this truck..
    I also have a 1989 3/4t Suburban TBI 454 on a stand in my garage /forums/images/graemlins/truck.gif
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Not sure if it's still a problem but I have heard that the 502's are notorious for using a LOT of oil. Like needing to add a few times before a scheduled oil change.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I'm sure that the dismal compression ratio of somewhere around 8.3:1 /forums/images/graemlins/eek.gif really helps to prevent pinging as well. /forums/images/graemlins/frown.gif But that can be a good thing when you're dragging way too much weight up a long mountain pass, keeping the cooling system on the ragged edge of its capacity. /forums/images/graemlins/cool.gif
  7. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Uhh, No. Have you driven anything with a 402 for an extended length of time? Comparing a SB to a BB is a retarded comparison. Even when the differenceis only 2 CI. My 402 runs close to 400hp with pretty much bolt on stuff. What does it take to get 400hp from a small block 400? Alot. /forums/images/graemlins/thinking.gif
  8. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    actually its very easy to make 400hp on a 400ci smallblock
  9. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    A mild cam in a SB400 w/, say... vortech heads, good intake, you would easily get 400+ torque and HP... Checkout last months Chevy HP magazine....
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    the BB heads are a much better design the sb
    that is the big difference
    canted valves less shrouding
  11. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thank you mj.
  12. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    Go with the 502, cost is same as 454/402 to rebuild, much torque....
  13. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I'm sure the proofessor is trying to be helpful, but....There's nothing wrong with the older big blocks. The only issue I'd take care of is the poor cam oiling. There are oval port heads (better for torque vs. the square port heads, which are better for higher rpm HP) that go back to the early big blocks, this is not an '88 and later-only thing. The old heads had guideplates too. /forums/images/graemlins/thumb.gif
  14. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    While were on the subject of big blocks. How much hp and torque could I expect from a '70's 454 long block. I see these motors for sale in the paper for around $750. With a rebuild, reconditioned heads, new alum. intake, and the proper cam what could I expect. This route wouldn't cost anymore than building a 383 out of my current 350.
  15. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Just for the record, my '68 427 with '75 454 oval port heads and a Comp Cams hyd. roller cam, Doug Thorley headers, MSD, Edelbrock intake w/ 670cfm Holley, 9.1 compression, 8qt. Moroso pan and external oil cooler, runs with the best of them. I agree about the early 454's being somewhat a problem. But I've never had problems with either of the 427's I've owned over the years. I like the internal balance of the 396-402-427 series but shy away from the external balanced early 454's. Max torque comes only from max cubic inches, all else being equal. For that, go 502.
  16. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    for torque, stroke wins every time....Personally I would go with a 496... The 502 is WAY over-square (too much bore, not enough stroke) but if you wanna run with the BIG boys go with a 540 or bigger...The 496 is just a 454 block bored .060" over (so 4.310") with a 4.25". But if you have the choice on the of the 3, I would get the one that has the GenVI block...I bet the 502 is in a Gen VI block...I would get that one, bore it over .030, throw a 4.25" Stroker crank in it, put on some "049" or "781" heads (or spend some green on the Edel 6045's. All this will put you well into the 500hp range...
    I say go with the Gen VI block b/c it is cheap and easy to use a roller can an you can use ANY BBC heads....The MKIV and GEN V block are expensive to use a roller cam ($800+) and you are stuck with the aftermarket roller lifters...
    But that is just me and I have a problem of not being able to leave well-enough alone..just ask everybody that wathced my COMPLETELY rebuilt a 454 the ran just fine when I bought it just b/c I could... lots of money after that, I have a strong TBI injected 460 (454 bored .030)
    chris
  17. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    The 502 is a serious motor. A friend of mine has one in his truck, it's nasty.
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    How about a 632. /forums/images/graemlins/laugh.gif
    85K5 3/4ton,14boltFF,10bolt,9"lift, 35"boggers, 16.5x14 welds, big horse 406SBC/700R4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  19. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    now your talking...
  20. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    too bad he would have to get a $2000 Merlin Block to accomodate the 4.600" or so bore...
