I need bolt help
Discussion in 'The Garage' started by sandawgk5, Aug 21, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I felt my Tcase hit the floorboard the other day. Ya strange I know. Well I slide under the truck to see WTF and the mount is there and bolted to the cross member but there are no bolts from the mount to the Tcase. Dunno what happened to them they are just not there. I need to know what size bolts those are as well as proper length so I can get replacments. It is for a NP-208 behind a 700.
    Ira
  2. 84zz4ss
    84zz4ss 1/2 ton status Premium Member
    Dec 28, 2004
    1,342
    Pensacola FL
    10X1.5 27MM length.
    Just put one in mine saturday. Don't forget the washers.
  3. sandawgk5
    Oct 28, 2003
    6,881
    What kinda washers in particular? The locking kind or just flat washers.
    Ira
  4. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    Just some flats with a little lock tite.
  5. sandawgk5
    Oct 28, 2003
    6,881
    Thanks Scott I will pic sum up on my way home this evening:D . It scared the **** out of me when I first heard it. The truck was acting weird under acceleration and I thought it was major axle wrap. Come to find out on the motor mounts were holding the drivetrain in:doah: .
    Ira
  6. 84zz4ss
    Dec 28, 2004
    1,342
    Pensacola FL
    Yeah I found out the hard way too. In the local area a little twisted and couldn't shift to reverse. Linkage was hitting front spring rear shackle. Found trans mount broken and about 1.5 inches too close to the driver side of the truck. Fixed it back to the mud.
