I NEED BRAKE ROTOR HELP!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Mar 30, 2000.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    changing rotor on '89.
    have the wheel off, hub partially disassembled.
    pulled spring, hub, etc, but am stuck at a round thingie with four cut-outs along edge. does this spin off?
    my buddy is doing the job with me, he used to run a tire shop, so he's not an idiot, but he's never done four wheel drive stuff.
    please help, i wanna drive home tonight!
    <font color=purple>delta9blazer</font color=purple>
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Yup, that need to come out. It's basically the nut that holds your rotor assmbly. to the spindle. You can fasten a tool out of some pipe, or goto a parts store and get a 4x4 spindle nut socket to get it off. Or, if you're lucky, you can manage to turn it off w/a screwdriver and pick up the socket when you get your rotors turned. Good luck
    the Goose
  3. delta9blazer
    1,646
    does the nut turn correctly to back out? or is it backwards thread?
    its on the passenger side, if that matters.
  4. Todd78/87
    Todd78/87 1/2 ton status
    Feb 18, 2000
    436
    Haines, Ak
    yes, it comes off normally on both sides
    Todd 78/87[​IMG]
    Alaska Bound
  5. delta9blazer
    1,646
    ok, just went to kragen and got the socket. wow, everything's easier when you have the right tool!
    thanks for the help!
