I need engine help?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ZfromNJ, Apr 17, 2002.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I am looking to replace my old beat up engine out of my 74 and put in a new engine. But since it is my daily driver I would to have a tranny that has overdrive. Any suggestions on what I should and should not get?
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If it is a daily driver and you haven't done a rebuild or anything like that before, I HIGHLY recommend a basic GM 350 crate motor. You can get one from Scoggin-Dickey (www.sdpc2000.com) for under $1500.
  3. Blue Meanie
    Blue Meanie Registered Member
    Apr 12, 2002
    61
    southern New Jersey
    what kind of motor are you looking at getting and how often do you use it to wheel? if you are looking for an overdrive tranny, i would go with the 700R4. i had one in my old blazer and didn't have a problem with it untill i beat on it in the woods. they are a little pricey, but thats the price to pay for the overdrive i guess. just my tid bit of info
  4. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    Thanks fellas. I will look on the website for the motor and My wheelin here in NJ is pretty much strictly beach riding and mudding.
  5. dyeager535
    26,980
    If you aren't really concerned about acceleration, I'd consider just running bigger tires or swapping axles out to something with a numerically lower gear ratio. At least you won't have to worry about the 700 then : )
