I need help adding PS pump and ALT to dbl hmp heads
Discussion in 'The Garage' started by 8_YOUR_H2, Dec 13, 2005.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I got my motor back from the machine shop today and I put on a set of double hump heads. I want to keep the alternator and PS pump in the same location and I am wondering if anyone has any info on this. I guess I don't HAVE to keep them in the same location but I need both alternator and power steering pump.
    The heads are off of an old 327 I believe and are 461 castings and the block is a mid 70's truck motor 2 bolt main, nothing sepcial. I know for a fact I will be able to retain the lower brackets that bolt to the water pump and I might be able to make something work for the upper PS pump bolt. The upper alternator bolt is what has me...
    Any help or tips greatly appreciated.
  2. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    70
    san francisco ,ca
    drill and tap, to correct thread. 3/8.
  3. cok5
    cok5 Registered Member
    Apr 27, 2004
    89
    I remember seeing some mounts on something that mounted the alt down low off the block or something like that. Not sure on the PS pump.
  4. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    The 69 350 I had used a rather rare factory bracket setup that put the altenator on the drivers side!-part of it bolted to the exhaust manifold,and it also used one water pump bolt if I remember right...the motor I had was from a Suburban,it was in my 72 Chevelle wagon on the Burb's 4x4 frame..
    Other than drilling and tapping as suggested,I'd say look in Jegs or Summit for bolt on alternatives..you'll likely never find a complete bracket setup unmolested in a boneyard..there are more than a few options as far as mounting brackets and locations..be careful if you drill and tap to not go too deep--you dont want to drill right thru into the water jacket..
  5. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    i believe that the alt bracket that was mentioned above is the one i used. it was factory on 55-80 vetts. it was the way i could get my alt to fit on my 400 sbc with 99 vortech heads while using long waterpump. the alt bracket uses a waterpump bolt and exhaust bolts on the head, placing the alt on the drivers side. the power steering pump bracket from the 72 jimmy worked. Gm still makes the alt bracket but it was 55 bucks with discount. i found cheaper ones on summit.
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    When I put headers on my 70 350 Burb, I lost the alt mounting hole in the exhaust manifold. Header Cos make a bracket that bolts over the header that allows the alt to go back in the stock location. Maybe this will help your situation.
