I NEED HELP AGAIN!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Jun 15, 2001.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    a wire on my distributor shorted against some metal. it is the wire that you would hook a tach to. it alternates on off. i believe it is brown. it is one of the three that go from teh coil into the distributor on an HEI system. anyhow the truck wont start now. it turns but doesnt start. could the coil or something have gotten fried? what could it be. i need help fast. thanks
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Off the top of my head, the tach I think, is off the coil. Check for burned up fuse link wire that runs to the Batt side of the coil.... HTH
    <A target="_blank" HREF=http://fwp4x4.rockcrawler.com>http://fwp4x4.rockcrawler.com</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I say it's either the fusible link, or a creamed HEI module.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I'm assuming there is no spark at the plugs... is there power getting to the dist/coil? I'd agree check the fusable link. Definetly could fry the module though. May want to check the coil as well... could of shorted that out
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I did the same thing sort of to my blazer but the truck would start as soon as you released the key. Did it all day the next day and then suddenly acted like there was never a problem. I would check your fusible links. They're about 2 bucks a pop. You'll see a frazzled mangled wire that looks like its been heat shrinked to death.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
