i need help asap
Discussion in 'The Garage' started by gunner2000, Mar 25, 2006.
  1. gunner2000
    gunner2000 Registered Member
    Mar 25, 2006
    30
    bentonville ar
    just took smoking and knocking 305 tbi out, put 350 tbi out of 87 pickup, used all parts off 305, tbi, sensors etc. i changed the cam out for the edlbrock performer cam for tbi part # edl-3702 in summit. truck will start but will only run for a few seconds any help would be great:bow:
  2. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    sounds like it could be a fuel problem, did you get all the oil pressure switchs/sensors hooked up?
  3. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    yes i can see the fuel going into the tbi
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Are you using the injectors for the 305 on the 350?
  5. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    yes i was told it would not matter, if i idle the motor up it will run but it cuts out
  6. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    are you tring to rev it up any
  7. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    i have also checked the timing as best i could for a engine that will not stay running, checked the vaules as well
  8. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I'm thinking it could be fuel presure and/or injector size
  9. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    yea i can rev it up but, it cuts out a little and as soon as i let off it will rough idle then die
  10. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    how can i correct this
  11. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I'm leaning that way too.
    Have you got the injectors from the 350 laying around anywhere handy?
  12. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    i was told from 305 to 350 you need 350 injectors... least thats what im changing on mine
  13. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    I don't know if tbi has the same regulator as a tpi but I was able to modify it to boost the pressure.
  14. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    I believe that the 305 and 350 injectors have different part numbers, with the 350 injectors having a 16% higher flow rate or something like that. The 350 has about that much more displacement vs the 305, so he could well be running way too lean. If he had the 350 injectors to swap in and try out, it would be one of the first things I'd try.
  15. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Actually the correct sensors do matter. The most important one is the MAF, it's calibrated for the 305 and you are pulling a lot more air by the MAF with the 350. Also you must have the the correct .bin for the 350. I'm not sure if the origional ECM will work or not. Most of the other sensors that do not relate to airflow *should* work. You will also need the correct (larger) injectors for the 350 (again you are moving a LOT more air through the engine than with the 305 and you have to feed it). You are not getting enough fuel to keep the engine running beyond idle so you will have to correct this.
    You really need to see what the ECM is seeing along with the information that the sensors are sending to the ECM. You need to download ALDL and start learning what your engine is telling you that it needs.
    You can start here: http://www.winaldl.webhop.net/. Also head over to www.thirdgen.org and start looking around. Thier search engine is temperally disabled until their change over to thier new server is finished, but you can use the advanced search option on google (there's a sticky on the DIY Prom page that gives you the directions on how to do this). The TBI and DIY Prom pages have a wealth of information and it is well worth the time it takes to do some in depth reading.:D
  16. tunedportk5
    Jul 13, 2004
    371
    Union City, CA
    second that
  17. hans999999
    hans999999 1/2 ton status
    Mar 9, 2005
    149
    southern connecticut
    when swapping a 350 in from a 305 i heard you can use everything but injectors,knock sensor,ecm. i think i read that about camaros when i was working on my friends thirdgen.
  18. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    i belive it has a map sensor, i did not even think of that, could i go to a salvage yard and get a ecm for a 350 to help, would it plug right in with no mods, and i will change the injectors, they do carry a differnt part number
  19. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    would it also help to tell you guys that i have the edlbrock performer tbi intake on the motor as well, wanted the cam to work as best it could
  20. gunner2000
    Mar 25, 2006
    30
    bentonville ar
    it does have a map sensor, and it also has the matching edlbrock performer tbi intake on it
