I need help asap
Discussion in 'The Garage' started by 77ChevyK10, Aug 30, 2003.
  1. 77ChevyK10
    77ChevyK10 1/2 ton status
    Feb 2, 2003
    317
    Laveen, AZ
    i am trying to put in new frount axle shaft seals but can not get the axle shaft out. i have the spindle and all that off. all that is on is the knuckle and the shaft is in. it should come right out shouldn't it?
    Andrew
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Yeah, it should pull off once you have the spindles off. Check to make sure its not catching on the knuckle as you try to pull it out, there is not a lot of clearance for it to fit through.
  3. 77ChevyK10
    Feb 2, 2003
    317
    Laveen, AZ
    thanks
    it just needed a little pring and it came right out.
    Andrew
