I need help, blazer shaking problem
Discussion in 'The Garage' started by bigbran45, Apr 18, 2005.
  1. bigbran45
    bigbran45 Newbie
    Apr 18, 2005
    Michigan
    I have 1990 jimmy, and it shakes going down the road. The faster i go the less it seems to shake, but going slow it shakes really bad. If i put it in neutral or let go of the gas it goes away, and if i rev the motor in neutral while rolling it doesnt shake. Its the same wheater im in 2 or 4. I havent tried 4 low. I have just recently replaced both u-joints on the rear axle and im going to try to replace the front ones tonight. The yoke on the rear end was kinda lose, so i torqued it back down. I can not figure out why its shaking so bad. I dont think its the motor or the tires.
    Any help is Appreciated
    Brandon
  2. TEAMROPER
    TEAMROPER Registered Member
    Aug 8, 2002
    29
    San Diego
    sounds to me like if it is not an alinement problem. You might have a bent driveshaft or a u-joint going bad..
    JD
  3. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I experienced the same right before my slush box TH350 turned to mush... Lots of vibrations only under power. Might pull that pan, if it is an auto, and look for metal shavings, burned fluid, or any other stuff other than clean fluid.
  4. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    same thing with my th350 when it died
  5. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    My money is on a bad u joint,
  6. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I could be way off here but could it be a tire goin bad or a tire outta balance?
    On my dads 91 k10 it would shake cause the front tires were goin bad even though they had a lot of tread left on em.
    side note dont by trail mark AT's they dont last.
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Vibration ?? or a shake ??
    My Suburban shakes going down the road, thought it was an out of balance wheel, found out it is a bent rim.
