I need help picking out a tranny cooler.
Discussion in 'The Garage' started by Chrisblazzer89, Jan 16, 2007.
What size tranny cooler?
  1. Imperial cooler 3/4 x 10 x 15.5
    5 vote(s)
    71.4%
  2. Imperial cooler 3/4x 11 5/8 x 11
    0 vote(s)
    0.0%
  3. Imperial cooler 3/4 x 7.5 x 15.5
    0 vote(s)
    0.0%
  4. Imperial cooler 3/4 x 5 x 15.5
    0 vote(s)
    0.0%
  5. NONE
    2 vote(s)
    28.6%
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok so called Advance Auto Parts and asked them what tranny coolers do they carry they told me they had Imperials Transmission coolers I asked for the biggets one they said 3/4 x10 x15.5 and its only 50 bucks. Is that to big for my application I will have a 3/4 ton 10B front and a locked 14BFF rear both with 4.10s and stock 350/700r4/208?
  2. sgarrison
    sgarrison 1/2 ton status
    Feb 4, 2005
    148
    Art's Bar and Grill Mt. Pleasant S.
    The bigger the better.
  3. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i like the b&m style ones, and get the biggest one they got.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I clicked "NONE" for none of the above. Its made better and will resist stones, debris much better.
    Use some aluminum flat stock and make a mount. Do not use the cable tie dealies that push thru the radiator. They WILL in time rub a hole thru the cores.
    Get this one... B&M from Summit
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    This is what I run.
    TRU-COOL MAX COOLER # K45FL 8.5x22.75x1-1/4, 40,000 LBS GVW
    And here is a pic for reference.
    Ira
  6. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    Not to hijack But could someone use a newish a/c radiator? I got a new one off my 93 blazer that i took apart and was considering using it for trans cooler.
  7. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,031
    1,347
    Kzoo, Mi
    I'd go with the plate type, there more efficient, and smaller.
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I would but it comes with no monting hardware. Whats up with that?
  9. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Does this come with mounting hardware? Where did u get it from?
  10. sandawgk5
    Oct 28, 2003
    6,881
    Yes it does. I do not remember where I got mine but they are in Ebay and online. Do some price comparison and see what you come up with. It also came with a thermal bypass to let the tranny warm up but in Socal it is not needed so It stayed in the bag. The cooler also came with ends and hose to attach the cooler.
    Ira
  11. sandawgk5
    Oct 28, 2003
    6,881
    Just to be clear the Trans cooler is the big one on the right of the photo. The one on the left is my PS cooler:D .
    Ira
  12. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Stacked Plate design is best -- I don't know the Imperial brand. The B&M that Summit sells have worked well for me.
    Bigger is better, no matter what. Especially with a 700r4.
    I have these on my trucks:
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70268&N=700+400004+115&autoview=sku
    or maybe it was this one
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70266&N=700+400004+115&autoview=sku
    I haven't bought one in a coupla years, so the prices seem to have gone up. Ten bucks one way or the other is nothing when compared to the hassle, never mind cost, of dropping your tranny and rebuilding it.
    As said, do NOT use those plastic stick-through things. Angle aluminum is cheap, easy to work with -- no welder required -- and our trucks have lots of places to drill into and mount. Some sheet metal screws and a little work with the drill and grinder, all hardware store stuff, and you're golden:
    http://www.slosh.com/ck5/tranny-cooler-mounting-1.JPG
    http://www.slosh.com/ck5/tranny-cooler-mounting-6.JPG
    http://www.slosh.com/ck5/tankie-dusty.JPG
    Also consider a temp gauge ... you can mix-n-match to build your own, or B&M sells a nice kit with EVERYTHING you need, plumbing and all:
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D80212&N=700+400004+115&autoview=sku
    I have one of these in my tow rig,
    http://www.slosh.com/ck5/trans-temp-gauge-1.JPG
    and on my 'wheeler, I used a factory water temperature sender and a modified factory gauge:
    http://www.slosh.com/ck5/temp-sensor-plumbing-2.JPG
    http://www.slosh.com/ck5/new-gauge-installed-3.JPG
    The latter is lots more work, but has that slick stock feel.
    -- A
  13. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    what a thermal bypass ? would i need it in new england?
  14. sandawgk5
    Oct 28, 2003
    6,881
    :dunno: Seems like one more thing to fail when you least expect it.
    Ira
  15. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    wat is this? pics?
  16. dremu
    Feb 27, 2000
    15,958
    452
  17. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  18. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Damn that is a large cooler....:eek1: :eek1: :eek1: :eek1:
    Might have to get me one of those....
  19. 85mudr
    85mudr Registered Member
    Dec 15, 2006
    17
    New Whiteland, Indiana
  20. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Hah! Just found out what the OE application is for those coolers. They're the trans cooler off the 6.0l Ford PSD's. You've got Ford parts on your GM! ;)
