I need HELP quicly bleeding my clutch!!!!
Discussion in 'The Garage' started by KrebsATM02, Mar 4, 2003.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Here is my situation, i'm putting a sm-465 in my blazer and decided to go hydraulic. The only problem is i couldn't find a bell housing, so i made my own bracket to hold the slave. The bracket is plenty strong and it mounts so that when the slave is pushed all the way in the fork is on the 16 little prongs on the pressure plate. Also, i made the bracket inside the truck on the pedal only to move an 1.5", because that is the stroke length on the master cylinder. I'm also using a hydraulic line, with an 1/8 inch ID. When i bleed, all i do is keep getting air. I took the slave off and held it down thinking air could get trapped somewhere. What is my problem???? I need this fixed now, i still have to swap a dana 60 in before saturday morning when i leave on a 14 hour trip to las cruces for spring break. Help me please!!!!! /forums/images/graemlins/1zhelp.gif
  2. captain chaos
    captain chaos 1/2 ton status
    Mar 29, 2002
    413
    dickinson, north dakota
    acouple times when i have had to bleed these and it wouldn't work out. i left the cap off with fluid in it, then took the slave off, (with hose attached) and pushed it in againt the frame. this pushing the air out the top. you should feel it getting more resistance after a couple of strokes.
    when you feel satisfied put it back on.
    i don't know what this is called, i just called it back bleeding.
    hope this help's and you can understand.
    dave
  3. KrebsATM02
    Mar 21, 2000
    553
    yeah i understand, the slave and master should have the same bore and length i would think, so pressing the slave would do the same thing as pushing the master. Anyone else??
  4. KrebsATM02
    Mar 21, 2000
    553
    help please!!!! I'm desperate!!!
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  5. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    Are you sure you don't have a pinhole leak somewhere letting air in? I've had a similar problem on a furd while replacing the master, and after changing the slave and hose the problem disappeared.
  6. KrebsATM02
    Mar 21, 2000
    553
    Everything is brand new???? Guess i'll inspect everthing better than i have tommorow. I've got to get this thing moving!!!
  7. KrebsATM02
    Mar 21, 2000
    553
    any other ideas?
  8. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Well, I know this doesn't really help you, but I have a s10 where I replaced all the clutch hydraulics and just couldn't get it to bleed. I got fed up with it, and didn't touch the truck for 2 1/2 months. I went to move it today, and it worked fine! /forums/images/graemlins/blush.gif
    One suggestion a friend of mine had, even though I never got around to it, was to lift the front of the truck way up so that the master cylinder outlet was at the high point. Then he said to take off the slave, wrap the pushrod and body with several layers of duct tape(to keep the piston from flying out), and hold it to where the bleeder is at the very top. Then have a friend push the pedal for you. He said that doing that always helped him with stuck air bubbles whenever he had a particualry difficult truck. Good Luck! /forums/images/graemlins/thumb.gif
