I need help so I can fix this Sunday fuel or ground
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ramjet gmc, Aug 2, 2003.
  1. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I have the ram jet 350
    when I try to, start the motor after running a it will not start it seems like a fuel thing because it will run for 4or 5 turns and stop. Wait 5 min and it will start right up quickly. do you thing it could be a ground the ramjet wire harness is grounded well and that was the pos and neg on it for the fuel pump /forums/images/graemlins/crazy.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I doubt it's a ground problem, if it was I would think it wouldn't start at all. But then again, I'm no expert.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    sounds like maybe an ignition problem...
  4. ramjet gmc
    Dec 19, 2001
    3,370
    well i can heer it fire up and then it quits i will look for sperk next time but i bet it is ther
  5. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    timing ok?
  6. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Have the ign module tested at AutoZone, and look for code 42. Is the fuel filter new(er)?
    Hope you get it figured out today! Let us know how you fixed it! /forums/images/graemlins/wink.gif
    -Dan
