I need help w/ Blown Engine 1989 TBI
Discussion in 'The Garage' started by TEXICAN, Mar 26, 2006.
  1. TEXICAN
    TEXICAN Registered Member
    May 27, 2005
    30
    TX
    Im new to all this. Just bought my first blazer on Monday, the engine was shot i didn't know it. The engine blew after i was almost home 80 miles later 10 miles from town. I need suggestions on what to do w/ the engine. How much horsepower can you make w/ a stock TBI. :confused:
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Define blew.
  3. TEXICAN
    May 27, 2005
    30
    TX
    Well the car sells man lied and told me my K5 had a strong 350. Well i made it 10 miles from town and the engine wouldn't crank. So we pulled it w/ a chain to my automotive school. Pulled the whole drivetrain. We took off the intake it was full of sludge and shavings. Pulled the heads one was cracked. A small piece of a pistion head was missing. We drained the oil you could see all the water in it. It was more of a sludge. Looked like milk shake. The tranny fluid smelled burn't.
  4. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    That's an unfortunate situation, to put it mildly. At least it sounds like the TBI setup works OK, so you can still use that.
    I have no idea how thick or thin your wallet is, and if you're in school, it's probably not sweating huge piles of cash, but perhaps the easiest thing, and fairly cheap as engines go, would be something like this long block. 3 year 50K mile warranty, 4-bolt mains, LT-1 rods, and 50HP more than the stock 1989 350TBI. Just the basic 10067353 without the intake (just use your TBI setup, distributor, and so forth), although you might need to have the TBI's ECM reprogrammed to work with the cam, or just throw in something like an edelbrock 3702 cam kit (it's computer-control compatible) and run it that way instead.
    After you get it running, then you can powerbrake on the car dealer's body if you wish.
  5. Creek
    Creek Registered Member
    Mar 17, 2006
    36
    Mint Hill, NC
    His TBI intake will not bolt up to that motor.
    David
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The answerer is simple........ All you need is money and one of these
    BTW I have been dealing with Extremefi for awhile. Always been pleased with their stuff.
  7. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Dammit, that's right, it won't. They (GM Goodwrench) do have a TBI replacement crate engine for a few hundred bucks more that would be a direct fit with that intake; I'll look for a part number and some details for that one (sorry about that, my error).
  8. 1985_K5_Silverado
    Dec 21, 2005
    984
    Corn Country
    Here's the TBI replacement long block. It's a little tamer in the HP department, as well as having 2-bolt mains (vs the 4-bolt mains of the other), and it's got those swirl port heads.
  9. TEXICAN
    May 27, 2005
    30
    TX
    Man it was worth spending the $25 for coloradok5 I really appreciate every ones help.
  10. TEXICAN
    May 27, 2005
    30
    TX
  11. fasthumpman
    fasthumpman Registered Member
    Oct 22, 2005
    85
    Texas
    how long did you take inspecting the motor/drivetrain before you bought it???? sounds like yuou were far from a mechanic you can trust but i always have a one check out a vehicle i buy.......since im not the smartest bout automobiles. im sorry you got ripped off. it happened to me but not with the motor....i just got screwed with a sh!t load of rust hiddin by carpet and paint! goodluck buddy
    also what part of texas are you from.... fort worth here
  12. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    You said "salesman" in one of your posts right? If you got this from a dealer I would go back rip them a new ***hole! They should pay or replace if you were only 80 miles away.
  13. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    When my 89 with 225,000 finally needed to get replaced, I just went to my local chevy dealer and got a replacement new crate engine.
    3 year warr. no questions about fitting, and plenty of power. Not the cheapest, but probably the most reliable.
  14. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    :pimp:
    :pimp:
    That would be a real nice upgrade to my K5.
