I need help w/ the 4-link analyzer
Discussion in 'Center Of Gravity' started by SCOOBYDANNN, Nov 26, 2004.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I am a first time designer of a 4 link and wanted to use the analyzer for some further info.
    I figured out everything pretty easily ,but, where do the x (frame end and axle end) come from?
    I have a scale model on graph paper and i think i have all the #'s.
    thanks
    dan
  2. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    SD,
    Are you talking about ExcelCAD?
    If so, consult the "tab" called "HELP - Coordinate Diagram"....that will show you what the X,Y and Z coordinates are supposed to represent. If you still have questions let me know.
    /forums/images/graemlins/waytogo.gif
  3. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    this one. http://home.earthlink.net/~triaged/Files/4LinkCalculatorV1.5.xls
    I understand "y" and "z" because it explains it when you drag over the bix, but i just don't understand what numbers it is asking me for for "x". i am assuming it is the length of the links but then i am confused on the "axle end" and "frame end"
    in the "upper" box the #'s that are already in there are (32 for the frame and 0 for the axle)
    and the lower is (49/f and 3/a) where does that 3 come from?
    i do understand these are just thrown in numbers, but the 3 throws me off.
    thanks
    dan
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Dan,
    First of all, do yourself a favor and download a newer version of ExcelCAD....that one you're using is ancient!! /forums/images/graemlins/grin.gif
    Get ExcelCAD v2.1 here:
    www.gregblanchette.com
    Next, for your answer (though it will be more obvious in the version you'll be getting because it's GRAPHICAL)
    "X" is referring to the position of the link relative to the axle centerline. In your previous question....one of the links is directly ABOVE the axle centerline, so the value is 0, but the other link is 3 inches offset from the axle, hence the value of 3.
    Check out v2.1, it shows not only a side profile of the suspension, but also a top view. Even if you don't understand what all the "blue" cells are for, with some experimentation you'll be able to figure it all out. I believe there is also hidden "comments" on almost every cell to help explain either what kind of value to put in, OR if it's a calculated value...what the value represents.
    /forums/images/graemlins/thumb.gif
  5. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    AWESOME! thanks lets see what i can do.
  6. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    holy spit and shenanagins thats about 300x better--thank you.
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Glad you like it. There was a lot of effort involved to get the graphical aspects incorporated into the v2.x releases. /forums/images/graemlins/shocked.gif
    Sounds like my effort was not in vain.... /forums/images/graemlins/thumb.gif
  8. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    man thank you---this is gonna really help me understand what is going on when i start this. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I just downloaded this for the first time... all I can say is WOW!
    Thanks!
  10. mnstrburbon
    mnstrburbon 1/2 ton status GMOTM Winner
    Apr 6, 2007
    2,004
    Buena Park Ca
    Digging up an ancient one here but is this program still available starting a new project and maybe this could help me. the link looks dead? or am i missing it.
  11. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,066
    190
    Colorado
    4 link calculator is still alive and good. Search Triaged on Pirate.
  12. mnstrburbon
    Apr 6, 2007
    2,004
    Buena Park Ca
    Thanks found it now the fun part of figuring it all out..
  13. howdiy
    howdiy 1/2 ton status
    Jan 28, 2004
    3,309
    Fl
