I need Help What are my Options?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Dec 26, 2000.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I put a 203 tcase in my 84 blazer now the drive shaft will not bolt up to the rear cuz the ujoint is to short. What options do I have in making this work or do I need to swap axles to?
    Scott
    78blazer
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I believe you saying the u-joint is too short, not the drive shaft? If so, find out what u-joint does fit the rear and get a hybid joint, with one size on half and another on on the other half. That's all I can think of!! Good luck.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    If you switched from a 208 to a 203, you might have to run the rear driveshaft that was on the 203, I believe the rear yoke should bolt right up. Hope it works out for ya.
    "I'm not stuck...I'm just re-evaluating my line"
  4. 78Blazer
    873
    Michigan
    Thats my problem it origionally had the 208 now a 203 and the driveshaft wont bolt up to the rear the 203 shaft. I never had the one from the 208. Im gonna have to try to find this hybrid ujoint I guess and hope it works..
    Scott
    78blazer
