I need help with a couple calculus questions.
Discussion in 'The Lounge' started by colbystephens, Feb 27, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    not real tough stuff here. anyway, i'm trying to find the limit of (t[sup]2[/sup]-4)/(t[sup]3[/sup]-8) as t tends to 2. i can't figure out the generic form of a[sup]3[/sup]-b[sup]3[/sup] so i can determine how things cancel out. by generic form i'm referring to, as an example, (a[sup]2[/sup] - b[sup]2[/sup]= (a-b)(a+b).
    also, i'm looking for the limit of (sqrt(x[sup]2[/sup]+x+1)-sqrt(x[sup]2[/sup]-1)) as x tends to positive infinity. when i calculate it, i get + or - 1/2. can someone verify that result for me?
    thanks!
  2. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    hmmm. looks like my html code doesn't work. i'll try and fix that. for now, where it says [sup]2[/sup] i'm referring to "squared" or "cubed" depending on the number between the code. thanks!
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok. i don't know how to format it. sorry.
  4. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    use this x^2, or x^3
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok - got the first one figured out. can someone still verify my other question tho?
  6. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    I'm still confused on your html code or else I could help
    ok give me a couple minutes but from looking at if a little harder I got
    (sqrt(x[sup]2[/sup]+x+1)-sqrt(x[sup]2[/sup]-1)) =
    Lim x->+ infinity sqrt((x^2)+x+1)-sqrt((x^2)-1) and you can use the limit laws to break that up to lim x->+ inifinity sqrt((x^2)+x+1) - Lim x-> sqrt((x^2)-1)
    ahh my brain is fried right now and its been 2 yrs since calc
    Ok you probably dont want to do that because that puts it into an indeterminate form. Good luck sorry I'm no help.. but atleast I tried
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks for the try. i found out that my answer is not + or -, it's just + because i'm going for positive infinity.
  8. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Second answer... approaches (+)infinity.
    x^2+x+1 > x-1
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm pretty sure that's not correct. as x tends to infinity, it should tend to +1/2. but, if you care to explain, i'd be open to objections.
  10. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Power rule
    x^n > x^m => lim[x->inf] ( x^n - x^m ) = inf (sqare root of x^2 is x, and x is x^1/2)
    Also:
    lim[x->inf] x^n = ( lim[x->inf] x ) ^ n is true IIRC
    edit:
    Im a dumb****... didnt see the second part is x^2... thought it was x
    oops... might be 1/2 then
  11. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Hrm... what's your proof for 1/2?
    I think I can prove infinity with the squeeze theorem.
    I just broke out my calculus book :(
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    after multiplying by the conjugate, and cancelling, you end up with x/(sqrt(x^2 + x + 1) + sqrt(x^2 - 1)), then pull out an x^2 from the denominator so that you have x/(sqrt[x^2(1 + (x/x^2) + (1/x^2)] + sqrt[x^2(1 - (1/x^2))]. Then, one can take the root of x^2 so you end up with x/[(x)(sqrt(1 + (x/x^2)+ (1/x^2))+sqrt(1 - (1/x^2)]. Then you separate it so that x/x=1 and you are left with 1/[(sqrt(1 + (x/x^2)+ (1/x^2))+sqrt(1 - (1/x^2)]. Then, factoring infinity in for x, everything with an x denominator effectively goes to 0 and you're left with 1/(sqrt(1)+sqrt(1)) which equals 1/2. Notice that the x in red above should have been pulled out as an absolute value, but since we are only dealing with positive infinity, only the positve x need be considered.
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I got infinity doing it in my head. What calc is this? I II or III (so I can kinda know what rules you are allowed to use)
    Even if they approach infinity at differing rates, it is going from the positive side so that negates a bunch. The intermidiate found using the limit laws allows for an 'infinity - infinity' situation wich you can L'Hptel (sp = bad) down to infinity - infinty again giving the limit is zero. Do it again and you have infinty. (I am still to lazy to find a pencil and paper so this is just from memory and brain work)
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    effectively calc 1
  15. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    L'Hopital!!!!! I forgot that rule.
    You can prove it with L'Hopital easily
    (the square root really has no affect on the outcome of this problem... just a small nusance for using the proper limit laws)
    Get rid of the x^2
    x+1 > -1
    Infinity
  16. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    not familiar with any of that new age hippity-hoppity. care to explain?
  17. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Erm.. forgot the whole rule
    2x+1 > 1
    Infinity
    Anywho, I'm gonna take a picture for you
  18. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    That actually made smoke come out of my ears. Seriously, I'm worried it's gonna set the smoke detector off. :eek1:
  19. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Note: You can use L'Hostpal recursively....
  20. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Most instructors make you earn L'hopital the hard way. It does make limits super easy. Should be in your book, it is probably 2 sections ahead of where you are now.
