i need help with getting it running smooth,air leak maybe?????
Discussion in 'The Garage' started by boggerless, Sep 23, 2004.
  1. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    all right, here it is. it still runs like crap. hear is what it sounds like after starting JR and letting it run for a couple minutes( with the choke pulled all the way shut). BUM BUM BUM POP BUM BUM BUM POP POP BUM BUM BUM BU _POP.what the hell is it???????? and the choke needs to stay shut to run. /forums/images/graemlins/dunno.gif please help saturday i want to get her running so i can start driving the stupid thing. THANKS daryl /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  2. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Just a total guess here but one of the things I noticed on my Holley I rebuilt over the weekend. Could the the secondaries be opened slightly? Mine had an adjustment screw that wasn't allowing the secondaries to close completely. Just a guess as I said.
    BTW any info on the shipping for those carbs?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it doesn't matter what carb you put on it? do you have the plug wires in the right spot?
  4. boggerless
    May 26, 2003
    22,728
    96
    i'll see how much to ship monday, i'm sorry i took so long , i tried to get the guy's from texas to find some one to get them to you for free. i didn;t work. /forums/images/graemlins/frown.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  5. boggerless
    May 26, 2003
    22,728
    96
    i'll check again but it ran pretty smooth berore i changed the carbs(pointlessly). other than it needed the choke halfway shut. now it needs to be all the way shut and sometimes it seems thats not enough. thats why i think it's an air leak. does the quadro junk gasket have a fit problem with a carter AFB carb? it seems to fit ,maybe thats it. /forums/images/graemlins/confused.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    No problem at all, thanks for trying. I did have an idea about your carb issue. could the carb mounting on the intake not be not flush? Like maybe when the carb is on it is not sealing to the intake. Only thing I can think of that would not change between carbs.
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im not sure what the carter AFB looks like, never used one or seen one, so /forums/images/graemlins/dunno.gif
    i think as long as both are a spread bore it shouldn't be a problem, did you try a new gasket? its hard to jugde what it is with out actually hearing it, i need to come over there and help you /forums/images/graemlins/thinking.gif
    you got PM /forums/images/graemlins/woot.gif
  8. boggerless
    May 26, 2003
    22,728
    96
    thats what i'm thinking. we'll see tommorow?that's my quest. /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. boggerless
    May 26, 2003
    22,728
    96
    the carbs are pretty much the same size and bore,i was just wondering maybe the casting is different TJ /forums/images/graemlins/confused.gif(steve needs a hammer graemlen or a mushroom cloud). /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    One carb is squarebore , one is spreadbore . You need one of each thin gasket , and the little thin adapter plate to make sure it fits right /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  11. boggerless
    May 26, 2003
    22,728
    96
    thanks bro, i had it running alright today,BUT after i triple checked every possible in take hole, it blew the oil pressure line /forums/images/graemlins/angryfire.gif half the truck was covered in oil.POS POS FOOK oil all over the driveway.SOB /forums/images/graemlins/angryfire.gif try again tommorow. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    carbs always get blamed for ignition trouble
    if you need to impede airflow to get it to run then it is lean
    now why is it lean?
    vacuum leak or improperly set idle mixture?
    or do you have a bad plug wire, fouled plug
  13. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Hey Boggerless, just wanted to check back with you about the shipping.
  14. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
  15. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
  16. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Any update on the shipping for those carbs? I am still interested if your offer still stands. If not just let me know so I can start looking around locally.
    Monty
  17. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Any news?
