I Need Help With my TBI Injection Hesatating
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pplblazerdude, Nov 22, 2002.
  1. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    I have a 88 fullsize blazer and it has a 350 with a tbi and when i stop and bearly hit the gas anuff to just get it to putter the truck starts to hesitate i mean it will start to act liek it is going to die and jerk along but once i get going it runs good does anone know why it does this if so plz help me. /forums/images/graemlins/k5.gif
  2. unsane
    unsane Guest
  3. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    When was the last time you replace the fuel filter?
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I second the fuel filter..my K% ran like crap until I found that the fuel filter was plugged solid with crap...Replace the fuel filter, run som BG 44K through it and see if that helps...
    Chris
  5. husurddy
    husurddy 1/2 ton status
    Jul 28, 2001
    108
    Snow Hill, Maryland, go east \'till you hit water
    My (87 tbi) hesitated on initial acceleration and it drove me crazy for a while. I was stumped because I had a fresh tune-up, EGR and 02 sensor, filters ect. Come to find out my new EGR was sticking. I took it back and replaced it and viola, problem solved. /forums/images/graemlins/grin.gif …Bryan
  6. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    check for a restricted fuel filter or low fuel pressure. If that is ok and your ignition system is well tuned, I would check the TPS.
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    If the EGR valve isn't sticking (or stuck), replace the IAC solenoid. Cheap and easy fix.
  8. YtseJam
    May 19, 2002
    147
    CT USA
    If the EGR valve was sticking or stuck, it would stumble and idle rough. The IAC will not cause the hesitation. If anything the IAC will give you a high, low or hunting idle speed if there is a problem or a vacuum leak.
  9. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Wow.
    By the way he describes his problem, it is stumbling.....
