I need help with the install of my new body bushings
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by blazin72, Aug 3, 2001.
  1. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I got all of them in the very back ones and the ones under the front floor board and the one right behind the seat bolt down tight and snug but the one right in front of the rear wheels and the two behind the rear wheels doesnt seem to want to pull the body down against the frame.
    It just smashes the bottom bushing and the top one is loose,
    What do I do to correct this.
    Did anyone else have this problem.
    Thanks for any help.
    Blazin72
    Blazin 72
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you have the hard top on? Do the doors shut well? Did you reuse any spacers that might have been in there with the old ones? Did you get them mixed up? There are a few different heights for the top half the mounts in the kit.
    It was recomended to me by Steve Chin that I do the body mounts with the hard top on to help line everything up when I do mine.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  3. Crushergmc
    Crushergmc 1/2 ton status
    Mar 17, 2001
    181
    Oregon
    I wonder if loosening the others until they are all installed would work better. Then tighten in a alternating pattern like heads, lugs, etc. That's the way I planned on doing it. I didn't know about the spacers but luckily I put them in a bags in the order I removed them. Good Luck, let us know how it comes out.
    "KEEP IT DOWN"
    70 Jimmy, 454, 2wd
    56 GMC, Big Window
  4. Crushergmc
    Mar 17, 2001
    181
    Oregon
    I just finished putting a set on a Blazer and had the same problem. Turns out I put a short bushing in the front location. Changed it to the taller one and everything fits perfect. Good Luck.
    "KEEP IT DOWN"
    70 Jimmy, 454, 2wd
    56 GMC, Big Window
  5. blazin72
    Oct 24, 2000
    279
    Oklahoma
    Crusher,
    Could you give me some more info on excatly what you did,
    What locations and which ones did you get mixed up.
    I thought I did them just like the book showed.
    But I wouldnt bank on it.
    Blazin72
    Blazin 72
  6. Crushergmc
    Mar 17, 2001
    181
    Oregon
    blaze, I'm assuming that all support kits are the same. The front pair under the floorboard (left/right) have a thicker upper bushing than all the others including the core support set. Hope this helps.
    "KEEP IT DOWN"
    70 Jimmy, 454, 2wd
    56 GMC, Big Window
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i had some problems with mine.i had the top on when i fit them in. i had a hell of a time with the rear mounts. i may still need a spacer for the ones right behind the front seats. door closed/opened ok till i took the top off, but that usually happens. if you find something keep us posted.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
