i need help with tire size
Discussion in 'The Garage' started by chevysupermudder, Jan 18, 2005.
  1. chevysupermudder
    chevysupermudder Newbie
    Jan 18, 2005
    thonotosassa,fl
    i have a stock 81 k5 what would be the biggest tire i should use without breaking anything like an axle
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    depending on the condition of your springs you could fit up to 33s without doing anything, but 32s should fit no matter what
  3. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    The skinny pedal regulates breakage:dunno:
    It's all in how you use and abuse the rig:whistle:
  4. chevysupermudder
    Jan 18, 2005
    thonotosassa,fl
    tire size
    my truck is stock.im stuck on whether i should get a 8inch lift or 6 because i would like to get 38 inch but i dont know if they will break cuz they are so big and the axles arent
  5. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    I always heard that 10bolts on 1/2tons could handle 33s just fine and 35s were pushing. 38's I'd say if you are just gonna drive it and not wheel it or do burn outs. I'm running 33s on my 85 K10 and my axles are fine, just my gears are too high.
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
    Im with big jimmy on the breakage issue, i ran a ten bolt for about two years with my old 40s,
  7. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    i am thinking of purchasing a 85 k5 with a 3/4 ton up front and a 14 ff rear, it comes with 4 inch coils and leaf spring flip in rear (about 5 in i believe) and a 1 inch body lift on it right now. whats a good tire i can fit? i was thinking maybe boggers but what size? my friend keeps sayign nothing about 35's, i want 38's or maybe 39's o yea it has mild fender trimming and i mostly wheel in mud
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Like mentioned the throttle, driving style, and wheeling type are the major factors in what tire is max. Traction devices make it harder on axleparts to survive also.
    On 1/2 ton gear that gets wheeled the max range that will survive with good maintanence and a good driver is 37" or so. This is just a generalization but you get the picture. When you get to 35" tires you enter the breakage range. Anything above that is just pushing your luck harder. You can break things with less then 35's but you have to be doing something you probably shouldn't be doing or just completely throttle happy.
    Harley
  9. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    I ran 10 bolts and 38.5 for about a year the axles were open no problems when i weld the front and put a limited in the rear i broke axle shafts with at 33's but i have a heavy right foot sometimes:screwy:
  10. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I think the first thing you need to consider is what gears you have in your axles. My 81' had 10/12 bolt w/ 2.73:eek: :eek: and when I boriginally bought my truck it had 33's. My truck was so sluggish and undergeared. Go look at a gear ratio charts or calculators on google images or go to http://www.4lo.com/calc/gearratio.htm there are several others.
    if you have decent gears the biggest I'd go with your setup is 35's.
    Jesse
  11. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    well i am looking at getting better gears anyway, right now its 3.73 but i would like to get 4.88
  12. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    If you replace the front axle u-joints often (at least once/yr) and are easy on the throttle you can get by with 38's for a front 10 bolt....I do. Am I shopping for a D60? Yes. ;)
  13. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    awesome i was looking at the 38x15.5x15 super swamper tsl radial, sound like a good tire? i see alot of people running them
  14. bigyellowjimmy
    Jan 15, 2004
    2,105
    Chandler, AZ
    Very good tire, I like skinny tires myself as I see no mud, only rocks. I run 38X12.50/15
  15. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    you dont think thats a little too much tire for the frive train? once again 10 bolt 3/4 ton front and 14 bolt FF rear with stock 3.73 gears (im wanting 38x15.5x15 tsl radial)
  16. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    ive run my ten bolt with 38" tsls and 4.10 gears daily for 3 or 4 months and taken it on 2 or 3 trial run weekends without any probs(knock on wood). my theory is if you dont break it you wont ever have a good excuse to go bigger and better. i have a d60 ready to put in as soon as i can afford srw hubs or someone wants to trade (hint hint). so go big or go home(mainly just have fun with it)
  17. nerraw117
    Jan 5, 2005
    788
    charlotte, NC
    awesome iwould like to have 4.88 gears and a rear detroit later on, how much did that D60 run you and what vehicle did you get it from?
