I NEED HELP!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, May 18, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i rolled my rig not to long ago. i got everything on it back to working order. but i can't put in my windshield.i have it straight for the most part. but hte rubber from around the windshield will not sit all the way down on the windshield frame. i have tryed everything but putting heat on it. not sure exactly which way it needs to go. the whole thing is tweaked. if anyone has been through anything like this your help would be very useful. thanx
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Good Luck, sounds like the frame and the window are not the same shape. But I bet you allready knew that so back to my original thought....... Good Luck![​IMG]
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  3. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    you nailed it right on the head with that one. LOL the windshield is the shape that the frame is supost to be.
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    what about getting a cutsom plexiglass one?
    i dont know if urs is a daily driver, but if it insnt, that would be awesome.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  5. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i seen some kind of new glass in a four wheerer on peterson mag about some kind of new glass, the put it on a heep....
  6. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I know two people who rolled their k-5's. Both had to shave the glass to get it to fit back on the truck. It's the only way you'll get it in without breaking it. let us know how you make out.
    You call that dirty!?
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Just kinda of a silly question, but you do have the locking strip removed from the seal, right?
    <A target="_blank" HREF=http://fwp4x4.coloradok5.com>http://fwp4x4.coloradok5.com</A>
  8. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i probly sound dumb with this but what is the locking strip? is it the use to be chrome thingy in the rubber gasket? if so it would not help any right now.
    the glass that was in petersons is "speed glass" but is like 230 bucks.
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Exactly[​IMG]the locking strip, sometimes chrome, some black, pushes the rubber seal up against the frame and glass. A new seal and new locking strip will help installation, if the frame is as close as you can get it. If you're using the old rubber forget it. It's usually way to hard and brittle to make it seat. Install the rubber (WIITHOUT the locking strip) onto the glass, work the glass with seal into the frame, it will take patience for that. If you get it in there, then install locking strip. Hope that made some sense.
  10. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i'm not that far with it yet. the glass without the rubber on it dose not fit into the frame.
  11. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hey Stu,
    When I put my new window into my fiberglass top I couldnt get it in there for the life of me. I tried everything I knew. I finally took it to a glass shop and the guy took 2 minutes and wouldnt charge me so I bought him a case of beer. Worth a shot.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  12. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    there are some other things wrong with it too that i'm getting sick of toying with. so i'm thinking about bringing it to a bodyshop. don't like but i want my truck on the trail again.
    that and i'm not old enough to buy beer yet.
