I need helping pulling my trans
Discussion in 'The Garage' started by dodgetruck91, May 20, 2003.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    hello, I need to know how to pull my 700r4 from a 86 GMC siearra pickup. it is goin into my blazer which i just blew the trans on, I will be keeping the transfer case with the transmission. Any help at all would be great.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    you need hands on help, or you need instructions.
  3. dodgetruck91
    Oct 22, 2002
    99
    probably only instructions, unless someones here in milwaukee and want to help for free /forums/images/graemlins/smile.gif
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Remove all bolt's, fastener's in the following no's.
    1. Tran's to engine bolt's and Torque Converter to Flexplate
    2.Driveline's
    3.Crossmember
    4.Speedo cable
    5.Shifter linkage
    6.Kick down cable,[if so equipped pull tran's pan]
    or disconnect at carb.
    7.Dipstick tube.
    8.Electrical connection';s or plug in's
    /forums/images/graemlins/grin.gif
  5. dodgetruck91
    Oct 22, 2002
    99
    Thanks, Ill see how it goes pulling it out, i have osme one lined up ti reinstallit in my other blazer for $200, but maybe if its easy to take off i will try it myslef, anoy other tip would be great, otherweise i think this will help tons. thanks again
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    get enough air under your truck so you can fit under there, It would be best if you had a tranny jack, but if you dont, then i would try to secure the tranny to a jack, unbolt all the Lines, hoses, Linkages that you can see, then remove the bolts on the bellhousing, then take off the inspection plate, and un bolt the torque converter from the flywheel, disconnect both drivelines, then do the x member, drop the tranny and tcase together as one, un bolt the tranny from the x case, after it is on the ground, then bolt up new tranny, you will prolly be changing torque converters too i would imagine, so when you put the new torque converter (tranny is still on the ground) Look in the tranny where the torque converter goes and there will be 2 notches, you have to make sure the torque converter seats all the way bacck in those notches (it can be a bitch sometimes) Then Just Repeat all the steps above, and put it back in.... Youll want a friend or two to help.... Sometimes it can be a bitch to stab the tranny into the motor and get the bellhousing to line up, atleast it was for me, but ive only put in like 2-3 trannies ;P
    good luck, tell us how you did
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    disconnect the battery
    jack the truck up if you don't have enough room under it without jacking it up.
    pull both drive-lines. if you have a slip yoke rear then use a rattle paint can lid and duck-tape it to the rear when you pull the drive-line that will keep the fluid from going everyplace
    disconnect the speedo cable.
    remove starter
    disconnect shifters
    disconnect kick down cable
    disconnect weiring from tranny
    remove inspection cover that covers the flywheel
    remove the 4 converter bolts
    remove the bottom 4 bell-housing bolts
    put tranny jack under tranny and take the 2 tranny mount bolts out
    take the 4 cross-member bolts out
    slightly lower tranny then get the top 2 bell-housing bolts
    pull tranny back-wards slightly and start to slowly lower
    if you need bolt sizes let me know /forums/images/graemlins/thumb.gif
  8. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    Are you in Milwaukee, or close to it? When are you doing this?
  9. dodgetruck91
    Oct 22, 2002
    99
    How hard will it be to get at the top 2 bell housing bolts? will i need to pull the engien for this? thanks again.
  10. dodgetruck91
    Oct 22, 2002
    99
    im in new berlin. thnx
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you will need a long extension and a swivel socket to get them with the tranny slightly lowered or you can pull them first from the engine bay with a wrench. but i would do it from underneath with a long extension and swivel socket
  12. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    /forums/images/graemlins/rotfl.gif how are you planning to pull the engine with the top two bellhousing bolts still in? ;P
  13. dodgetruck91
    Oct 22, 2002
    99
    good point. /forums/images/graemlins/thumb.gif
  14. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, I'd be happy to help, but my truck is out of commission until Thursday night because my oil-cooler is acting more like a sieve right now.
    I know "nofeartruckin00" is in New Berlin. Maybe see if he's around and wants to do it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/grin.gif
