I need more help w/reverse lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sax Art, Jan 30, 2001.
  1. Sax Art
    Sax Art Registered Member
    Dec 12, 2000
    49
    Western, Wisconsin
    O.K. here's the deal. My 1991 has never had reverse lights since I bought it 6 months ago. I crawled underneath, but everything looks like it's hooked up to the tranny like it's supposed to be. So, then (with all of your help) I found the switch on the steering column (under the dash) I turned the ignition 'on' , put the tranny in 'reverse' , then tried ratcheting that switch back and fourth, but still, no go.
    What should I do next? I do have an electrical test light, but I don't even know where to start. I guess my question is, "what is the common point of failure for this system?"
    Thanks, you guys (and gals) are great!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Have you traced the wiring along the frame and back by where the harness goes through a small hole in the frame behind the bumper area? My harness was wore through from the frame rubbing on it. Maybe a wire was rub apart..
    Also, Did you check all your fuses??? :)
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    My wiring diagram is for '81-'85, but should still be close. The dark blue(dk green) wire comes from the fuse box. It goes to one side of the switch. It should turn the test light on when the ignition comes on. Current should pass thru this switch, (test light on) when in reverse, and go to the back-up lights via the light green wire.
    Michael[​IMG]
    <A target="_blank" HREF=http://www.jmartin.net/parker/goose.htm>http://www.jmartin.net/parker/goose.htm</A>
  4. Sax Art
    Dec 12, 2000
    49
    Western, Wisconsin
    Thanks! That helps a ton!
    I'll go home and check it tonite!
