I NEED MORE HORSEPOWER!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigoltrux77, Aug 15, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    I want to know what upgrades i can buy that will iv me the best horsepower for my money. I really want to be able to burn my tires (i doubt ill be able to)but im just sick of little kia's spankin my ass on the road, its JUST ISNT RIGHT! The stuff id like to to know about is: best ignition (distributor, coil, etc), exhaust (headers, mufflers etc), and anything else i can add or replace on my truck that will give me better HP and MPG. BTW im not a rich guy so it has to be reasonable, and something i can do in my driveway (mostly) Also, is it ok if i convert my column shifter to a floor shifter? what are the steps in doing that. Floor shifter look so cool! Thanks alot!!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    what size tires and what gears do you have? gears are the best way to get lost horse power back
  3. bigoltrux77
    Jun 12, 2002
    318
    Fort Polk, LA
    i have 35's and stock gears. I know i know...they suck, but icant afford to change them. How much would it cost and what size gears in a 12 bot would i need?
  4. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    Looks like you need more stickers. /forums/images/icons/grin.gif
    JB
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    stock gears could be anything from 308's to 3:73's with 35's i would run 4:10's and you would be very happy /forums/images/icons/smile.gif and you dont need to spend the $1000 to 1500 to change gears just put a 14ff with 4:10's you can get them for under $200 and then get a 8lug dana 44 with 4:10's for under $300 then you would also have the streangth of the 14ff /forums/images/icons/smile.gif i had a 12bolt with 3:73's and 33's and i shaterd my 12bolt in the sand/forums/images/icons/shocked.gif
  6. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Your profile says Dana 60s with 4.56s
  7. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Bolt-on on a budget, eh? Set of good headers and 2 1/4" exhaust should do the trick. You'll probably hurt performance if you go 2 1/2" unless you've got some BIG power. A fresh HEI would help too. I like the MSD HEI coil and module, while others are happy with genuine GM parts. Avoid Acell or parts store cheapies. A good advance curve would help things out too. I have 16 degrees initial, 36 at 3,000 rpm and 8 degrees vac advance on ported. It all varies motor by motor, but I guess you can see the difference between the old stock 4 initial, 24 degrees mechanical in by redline and 20 degrees vacuum advance.
    I would save the camshafts, intakes, and heads for a fresh motor when you save up some bucks.
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Well if all you want to do is spank cars on the road its time to go <font color="red"> On The Bottle</font color>
    Get a nitrous oxide system(NOS) and a set of headers. I can guarentee you will say godbye to all your Kia problems /forums/images/icons/grin.gif
