I need pics of your custom rear shock mounts.
Discussion in 'The Garage' started by Mudbug1979, Nov 17, 2004.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    I'm trying to debate on where to mount my rear shocks. I have been looking at mounting them from right beside the spring perch inward toward the center. It's a DD with moderate offroading, so I need what ever will be the best setup that will work for both situations. I'm not planning on putting them up and through the floor board so that's out. I can get any size shock needed so that's not a problem either. I'm putting the Bilstein 5150's on the front and the same on the rear. If you have pics, let's see 'em. /forums/images/graemlins/peace.gif
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  3. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    How long are those??
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Those are 14" travel 5150s.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Here's my setup.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ummm nope those are " i dont know what length they were on the truck when i got them rancho rs9000's that will be coming off as soon as i can afford more bilstien 5150's" /forums/images/graemlins/waytogo.gif
  7. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Here's a couple to make you scratch your head...... Rancho 9012's installed outside the leafpacks and NOT going through the bed OR inboarded:
    It's a custom lower mount (obviously!) and the upper mount is made possible due to a 2" body lift. As you can see from the last picture, I also didn't have to angle it forward very far forward to get the necessary clearance....I managed to fit a 12" travel shock in there and didn't have to cut up my truck to do it. /forums/images/graemlins/cool.gif
  8. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Do you have or can you get any detailed/close up pics of the upper mounts? I'm needing to mount or wanting to mount the same size shock on the rear of my 77 dodge m880. I don't want to do the stnd. /\, I feel you loose alot of shock perf. this way especially on road.
  9. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
  10. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    The upper mount is kind of "automatic" when you finish figuring out the lower mount bracket, and decide how much piston you want showing at static ride height. Once those items are decided, there's really only one spot for the upper mount to land.
    You can probably use those same F*rd shock towers in the rear also....that's what I'll be doing in the next couple of weeks. I can take some updated pictures once that's completed. /forums/images/graemlins/cool.gif
  11. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    Greg---the updated pics would be great--that's about when I should have the rear suspension done on the truck and getting ready to mount the shocks.
    I'm using the F250 towers up front with the bottom curved portion cut off so the towers don't turn outward. It causes interference prolbems with the steering shaft on the driver's side. Should do fine otherwise. I might look into using them on the back as well.
    Thanks for the info and ideas!
  12. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    whats the advantage of running the shocks like this/\ over stock location?
  13. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you can run longer shocks which will not be in the way when flexed up /forums/images/graemlins/thumb.gif
  14. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    remember though, the further off from vertical the shock is mounted the less effective it is.
  15. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Perfect. /forums/images/graemlins/waytogo.gif
  16. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Clearly somebody put some time and money into the top pic, probably for a show truck. That bottom one though is just plain scary. Those are the biggest blocks I've ever seen on a lift........ /forums/images/graemlins/yikes.gif
  17. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    Somebody please tell me where this truck is located. I need the four shocks in the middle. This would make life much easier if I could get them all off one end of the truck....
  18. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Look for the driver. I bet his teeth have rattled so hard they disintegrated. He'll be the guy at the show sipping his nachos and cheeseburger through a straw.....
  19. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    check my webshots in my signature i have a howlin off road rear shock relocation kit, made by 55willy on this site.
