I need some D60 edu-macation please...
Discussion in 'The Garage' started by shane74, Feb 3, 2004.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Are most D60 knuckle interchangeable between brands? Like..will a dodge D60 fit on For or Chevy D60's? My buddy has an '86 Ford F350 and needs a right side knuckle. If they can interchange, then maybe I can steer him to some one here with the right part /forums/images/graemlins/dunno.gif Just trying to keep the $$ flowing to the /forums/images/graemlins/k5.gif bretheren and help a buddy out /forums/images/graemlins/waytogo.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    im not a d60 expert but i think the only diff between the knuckles is on the ford the spindle is different. i think it has one more bolt holding it on than the chevy/dodge
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    As far as i can remember they are all different between Chevy Dodge and Ford.
    Fords are the weakest and have 5 bolts that hold the spindle to the knuckle i think instead of 6 like chevy/dodge.
    The Chevys and dodge's are interchangable the only thing is the dodge knuckles mount the tie rod about 1" or so higher than the chevy knuckles... So if you used one chevy and one dodge knuckle your tie rod would look awfully goofy higher on one side.
    If you had both dodge knuckles that would be cool because your tie rod will be up higher out of the way than with chevy knuckles.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I know chevy and dodge D60 parts interchange but I think the fords are a little different.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Ahem,
    The short side inner axle shaft is 2" shorter on a dodge than a chevy...
    And the tie rod location is higher on a dodge knuckle than a chevy.
    And the ubolt top plate on the passanger side, the bolts or studs that thread into the housing are spaced differently on a chevy/dodge.
    Other than that, i think everything else is interchangable.
    /forums/images/graemlins/woot.gif /forums/images/graemlins/waytogo.gif
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Ahem,
    [/ QUOTE ] Wow, that was fast, look at the post date. /forums/images/graemlins/smile.gif I'm sorry I meant that I thought the hubs were interchangable, I'm not to sure about the rest.
  7. nvrenuf
    Jan 7, 2002
    13,085
    251
    Mobile, Al.
    VERY FEW parts from a Ford D60 interchange with Chevy & Dodge. The knuckles are different because they use 5 studs to hold the spindle, not 6 like Chevy & Dodge.
    I bought a Ford D60 for parts once, really only the carrier and small parts were interchangable with my Chevy stuff.
  8. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    all you ever wanted to know about dana 60's here
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif Thanks! Thats some good stuff!
    Thanks for all the replies! Now I know what to tell him /forums/images/graemlins/thumb.gif
