I need some diff cover help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Can Can, Mar 2, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    This question is about a Dana 35, but I'm sure it relates to all diff covers. 1990 Comanche 2WD with a Dana 35 in the rear. It looks like the cover's never been off(it's the factory orange silicone), and for the life of me I can't find something small enough to fit in between the carrier and the diff cover.
    Has anybody ever run into this? I've tried a super skinny flathead screwdriver, a lino knife, and anything else really skinny, My problem is is that anything skinny enough to slide into the void isn't firm enough to pry the cover off.....
    Please help me out, brothers!!!!!
    <font color=red>DIGGING AND DIGGING AND DIGGING</font color=red>
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am not sure what a lino knife is, but I would try and get a exacto knife in there and try and cut the cover free instead of prying it. Or you might try and get an awl under the cover, and drive it into the diff enough to get a prybar in there.
    My Chevy isn't broken, its just out of gas. <a target="_blank" href=http://coloradok5.com/gallery/albuo73>My K5</a>
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    have you tried the flathead screwdriver, and hit it with a hammer? Then oyu can straighten it on the ground, just make sure the surface is flat and bang out the dent you probably made.
    90K5
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Try an old wood chisel(sp?)
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>I'm Discombobulated </a>
  5. Can Can
    15,552
    136
    Another name for a lino knife is a "banana knife"......
    Does anybody else have any insight?
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I'v always just driven a flat head driver or wood chisel in at a couple of different places and pryed off the cover when they are siliconed on. If it bends a little they are easy to straighten out.
  7. Can Can
    15,552
    136
    I tried the same thing for about 10 minutes with about 4 different tools and couldn't get that sucker to budge. Is there a chance a Dana35 has a different cover setup on it? The cover is right flush to the diff body with absolutely NO gap!!!!! Almost like someone at the factory torqued the cover down really hard......
    I'm almost ready to take a torch to the sucker and see if I can MELT the RTV a little bit. Would that work????
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Go to a local garage and ask the mechanic what they do when it happens.
  9. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    gasket scraper and a small hammer. it is wider and has a nice point to it. it doesnt bend it, and if it does it bends it less so it is easy to straighten. if you can do it from the top. i have never seen a deiff cover leak from the top. even if it is bent.
    Grant
