I need some help
Discussion in 'The Garage' started by stiches, Nov 16, 2005.
  1. stiches
    stiches Registered Member
    Nov 16, 2005
    72
    vallejo/lodi, CA
    Hey people...i am a newbie...yes i know...but lets get down to business...
    1978 chevy blazer 350 v-8 yada yada
    it has a lift kit...but no wedges for the rear axle so i am going though u joints like one a month...i need them wedges...anyone got any spares? please i am broke and i need them cheep...can't drive far and can't drive over 45 on my mph...any advice>
  2. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    how bad is your angle? do u know what degree shims you need?
  3. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    reply
    Honestly no i don't i talked to the previous owner he said its a 4 inch lift kit...doesent know the degree
  4. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    i picled up some shims at a local spring shop for mine when i first did my lift i think they were like $10-$12 each
  5. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    reply
    okay....around here all i have for shops are
    normal stuff ie kragen napa bws advance and pepboys
    machine shops
    speed shops
    and no 4x4 shops
  6. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    i have extras, but with a 4" lift u shouldnt be anywhere near the angle for that kinda damage. also they are cheap, run about $10 so hardly worth it after shipping.
    check other stuff to make shure ure not trying to cover up another problem.
    i run a 4" lift and 35" with no prob till about 100-110mph then i start getting some vrmmm vrmmmmm :D
  7. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    all i know is that wehn i look at the driveshaft..the angle is extreme...do you guys know any good u joints that are durable and somewhat cheep....what size for stock...i can't figre it could be anything else....plus when i put greese in the one that is breaking it is tight for one minture of tourture...does anybody know what kind of rims i can get with a 4 inch lift....i want to do a theme to my car...i am useing this beast for mostly street and want street apeal...i can already dust my friends 1990 civic hatch back
  8. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hey, brother, I hate to rain on your parade, but "parts wanted" posts aren't allowed in the Garage. Just thought you might want to know.........:thumb:
  9. SARGE
    SARGE Registered Member
    Nov 6, 2005
    8
    Washington
    What size tires do you have? Are your fenders cut out at all? I have 12" and 39.5's and don't have any problems! Measure the distance between the ground and your frame at the body mount just behind the front wheel.
    Stock height should be around 16.5", with 31" tires and if you have a 4" lift then you should be somewhere around 20.5".
  10. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    replying
    I know for a fact i am not rubbing anywere on the fenders...theres about i say a good 6 or 9 inches of clearence...i'll find out tomarrow about t he height...
  11. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Do you have blocks or add-a-leaves in the rear? If its blocks they are usually tapered and you might have them in backward.
  12. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Some 36" Irocks and 20" wheels yo..... That would be the shiznit....... :rolleyes: Not my tastes, but different strokes for different folks I suppose.... Hey, I got some stock springs I could trade you for your lift springs :wink1: You could still clear some sort of DUB's fine and your drivehaft angle would go away :laugh:
  13. stiches
    Nov 16, 2005
    72
    vallejo/lodi, CA
    reply
    I found the problem....on the u joint there was only one c-clip holding it on and two u bolts...make sense? anyways i havent tried to go fast yet but soon i will
