I need some help!!!
Discussion in 'Rocky Mountain Region' started by bbck5on37s, Feb 1, 2007.
  1. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    :1zhelp: I twisted the bleeder screw off of the right rear wheel cylinder while bleeding the brakes:mad: ...I pinched off the line so i can have at least front brakes......I have a 14bff. I have never been into one of these axles before and i dont want to mess anything up...Would someone be willing to help?????? Its kinda scary driving in this weather with only front brakes..
  2. 81 k5 jimmy
    81 k5 jimmy Registered Member
    May 15, 2006
    10
    Colorado
    You just need to remove the bleeder ,if you can with a easy out great ,if that will not work then just remove the brake cylinder and replace with a new one
  3. mrk5
    Apr 20, 2004
    12,333
    1,043
    Northern Colorado
    I've had good luck removing broken grease zirks with easy outs. Just like a bleeder, they already have a nice hole in the middle. You oughta try that first, I mean it can't hardly make things worse. :dunno:
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I would also replace the line you pinched off. It now has a weak spot, and you don't want it to bubble out and pop, leaving you with no brakes at the worst possible time.
