i need some help
Discussion in 'The Garage' started by bigoltrux77, Oct 27, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    i finally got my coil for my truck, i put it in and got everything put back. I hooked my battery to my dad's truck to jump it, but hen i turn the key all it does is make i clicking noise. It doesnt turn over. The starter is somewhat new. wat could it be? all i hear is a ticking sound. today is my day off so i need to get my truck running. Thanks
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Sounds like the battery is dead or almost dead. If it's really bad, even jumping will not work. Try hookin the battery from your dads truck to yours. If it works, your battery is fried. Test it by checkin it with a tester...Should read no lower than 12 volts I believe.
  3. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    if it just clicks when your jumpin it it could be the selenoid check the battery with a tester or if its real old and a generic battery i would suggest gettin a die hard and gettin rid of the other one.
