I need some opinions on labor cost.
Discussion in 'The Lounge' started by Esteban86K5, Oct 11, 2005.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I have a neighbor that wants me to build some things for him and I wanted to get an idea of what you guys would charge. It would be building 30 of the same item and it would include cutting, welding, grinding and painting. He is going to supply all of the steel and material I may need, I just need to do all the work. It would ba an hourly rate but I don't know what to charge him. I usually give a bid for the gates I build depending on their size. But this is different.
    Any suggestions?
    THANKS!!!! :mrgreen:
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I would consitter it as a regular job. Forget he is a neighbor or a friend if so. Charge what you would normally too do the work.
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    When I do side work I usually bid out my normal wage rates where I work. Don't lose money on it.
  4. Esteban86K5
    3,712
    Bakersfield, CA
    Well thats' the thing. I don't have a "REGULAR" rate for anything. I don't do this kind of work most of the time. he just wants me to do this cause he can't weld as clean as I can and he knows I would be able to knock it out faster then he would.
    kyser_soze, what is the rate you charge? :confused:
  5. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I would flat rate it, that way you could kick ass on the job, and there no question about what it will cost him, be carefull with that though!! :D
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Build one and see how long it takes you, then YOU figure what your time is worth. What do steel fabricators in your area charge? If you are as good as the pros in your area, then charge accordingly. The first one, record all your cut lengths, then you can cut multiples of each piece, lay them out and just wwork down the line. Do all your welding first, then the grinding and painting. This will cut down on your set up time and make the job go faster.
  7. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    I charge $25.00/hr. But this is not the only thing to consider when doing a job. You use your own tools, supplies and materials need to be provided for a cost plus type of job.
    Estimate the time of making one of these items and multiplying by the total number will give you the approximate cost.
    When you do an assembly type of job, the learning curve decreases as efficiency increases for the time it takes to do.
    Give him a flat rate cost using your first estimate of doing one of them and multiplying the number, after you make the first one.
    Most important. Do be fair about your work and make shure that both parties are very clear on the deal, then everything will work out good for both parties involved.
    Good luck!
  8. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I dont know what to charge but I highly suggest a written contract so protect all parties involved.
