I need some Q-Jet help.
Discussion in 'The Garage' started by Codeman96, Jun 22, 2005.
  1. Codeman96
    Codeman96 1/2 ton status
    Jan 22, 2003
    184
    Southeast Mo.
    I am in the process of rebuilding my Q-Jet to put back on my Suburban. I have it all apart but I screwed up when I took out the..... well I don't know how to describe it. It is the needle and spring in front of the power piston in the float bowl. I screwed this out without screwing it all the way in and count the turns. It appears that the pin in the piston uses this for a downward travel stop. So does anyone know how many turns out it should be? I have a rochester book nad the instructions but I am yet to find anything that refers to this piece, mainly I am not sure what it is called. In the instructions it lists a air valve to be out about 7/8 to 1 full turn is this it?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Depends on Application .
    Most performance carbs ship with it 2 turns out ( what I read on internet ) .
    My 305 passes emissions at 1 turn , runs awesome at 3.5 to 4 turns ( albeit rich ) .
    I have a good balance between power and mileage at 2 3/4 turns right now .
    And this is on a common smog era Quadrajet .
    You may have different needs and have to play with it since you moved it already .
    You can pop the plug in the airhorn over it off if there , or drill hole if not , tap it for a plug , and adjust it without tearing carb apart .
  3. Codeman96
    Jan 22, 2003
    184
    Southeast Mo.
    Thank you very much. I am running a Edelbrock right now and i just don't like it. I decided to rebuild my stock carb. The motor is a warmed over 350 (headers, small cam, Edelbrock Pereformer intake). This is my tow rig so it has a/c and all of the accessories attached. Any other pointers you might have before I start putting it back together?
    I appreciate the help. By the way any idea what that is called? LOL
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its called APT , its adjustable part throttle .
    Basically its your primaries . The stop is to limit travel of the rods through the jets .
    Only tips I have is keep it clean , and be careful . They aren't very hard to work on .
    that and watch when ya put the top back on , the choke rod likes to hang up in that little spot it goes through
  5. Codeman96
    Jan 22, 2003
    184
    Southeast Mo.
    One more question. What is the best way to remove the plugs for the idle air screws (the ones in the baseplate)?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Dunno , everyone I have or had, had already had them removed :D
  7. dyeager535
    26,977
    Way I see typically done is to grind the metal away underneath the plugs.
    I too have never had to do remove them, but I can tell that is how the PO's have done it to the ones I've got.
  8. Codeman96
    Jan 22, 2003
    184
    Southeast Mo.
    All is done its on and it started. But it is getting late. I am so tired I managed to put the friggin' gasket on backwards, can we say massive vacume leak. LOL I changed it around and it idled fair. I'll break out the vacume gauge tommorrow and get her dialed in. Thanks for the help guys.
