i need some shifter ideas!!
Discussion in 'The Garage' started by ilikeitloud, Mar 11, 2005.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    i busted my linkage today in the jimmy.. i never liked having it on the column. i was wonderin if there are any good floor shifters that work well in the rig.
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    ryoken just put one in his. he has some pics in the gallery of it
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have a funny Idea for mine , cheap cable shifter like a Indymatic , shift boot , and keep the clutch pedal in for looks :D
  4. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    well, i'm absolutely in love with my AC.. the enjoyment level of my driving went up substantially... :D
    with my 700r4 i do alot of bouncing between 3rd and 4th. i just leave it in that gate and bang it back and forth.. i removed the top gate on the right for a straight run down to 4th. so its fully gated 1st thru 4th and free up to park. works sweet...
    its real solid from detent to detent and side to side.. real positive.. nice quality cable.. mines full custom mount so i can't attest to mounting the console they sell with it..
    wait till you guys see what i'm doing with the flipup hatch... ;) way freakin cool :woot:
    the only possible complaint i could have is, it's not lighted... no big deal driving, but Jersey's kinda funny about things like that.. have a couple green LED's that will match the lighted toggles and digital clock i put in behind the cupholder.. gonna put them down in the shifter body so they glow green out. should look good and appease any inspection nazi... ;)
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Can you briefly explain the cable routing from where you have it mounted?
  6. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    sure... got the standard 5"er i believe.. the box has 3 walls that run from front to rear. a left, right, and one the width of the shifter on the left/middle..
    here, wait, a pic is simpler... ;)
    hey, i got money down there! :eek1:
    cable worked out well for me.. they don't give you a grommet for the sheetmetal, but i had tons laying around... you can change the angle the cable comes out of the shifter.. i believe every 45 degrees around the bottom. just disassemble and reposition...
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Very cool - thx!
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Also while we are here - details on the console? Or should I wait until your done with the flip up hatch project?
  9. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    well, the console is made of a machine-made epoxy composite, kinda like fiberglass. extruded under high pressure. brutally strong.. all pieces are 1/4 thick. it comes in 4'x8' sheets.. also lots of beam and channel configurations.. we use it extensively in the boats.
    http://www.pultrude.com/stand.html
    works just like fiberglass. cut pieces to size. have to use diamondtipped blades.. channel or tapercut ends and epoxy glass tab the corners.. basically bonding your joints.. i have 1"x1" hardwood stock in some strategic joints inside for added strength..
    primed and painted like any fiberglass item.. its pretty freakin bulletproof. eventually it'll need to be modded to mount to an integrated cage, but i don't forsee an issue..
    the flipup hatch project involves all black hinges and pushbutton lock.. i'm going to have the big section to the drivers right, hinged in the back like normally with the lock up front. but the narrow section to the left over the cubbyhole/cable area will be hinged to that piece on the right.. so i can open just the cubby by flipping the small one to the right or open the whole thing.. the hinges are nice anodized marine units with detents at different points. i'm stoked on the hardware, just ordered it today. should work well.. pics to come...
    i'm in the home stretch on my Autometer dash made with the same material and construction and satin finish too..
    well, alright, i've got alot to do, but its to the point where i can see "light" at the end of the project and am stoked.. :woot:
    and to help steer this one back on track for the original poster.. i had also considered a Lokar and have heard good things about em. ;)
  10. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I really like your console! Thats pretty awesome.
    P.S. What did you do with your column shifter?
  11. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    thanks, i appreciate it.. :thumb:
    its coming around.. the digital clock i added behind the cupholder looks trick with the lighted switchs that have no actual destination at this point... ;) i'm also in the midst of a breaker/power box install in the lower front inside to feed said switchs and clock.. need to find a use for those... :thinking: :rotfl: the big compartment also holds my CD changer...
    and the column.... anybody got a manual, no tilt, no cruise column with wiper control for sale? ;)
    i just gutted all the linkage stuff down below back to the column, pulled the arm off inside and pinned the collar in the up position.. found that one out the first drive to work. the collar shifted down and wouldn't let the key turn to start it again... :doah: :rotfl: hopefully i'll find a column at the swapmeet next month...
  12. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I really like my Truck Mega shifter. It would be worth doing a search as this was covered in depth several months ago with lots of people posting pics up:)
