I need some suggestions.....PLEASE....
Discussion in 'Rocky Mountain Region' started by bbck5on37s, Feb 13, 2007.
  1. bbck5on37s
    bbck5on37s 1/2 ton status
    Jan 3, 2007
    543
    Denver Colorado
    When I got home from Carnage on Sunday I noticed my Blaze was no longer siting level like it did before. I started checking it out and found out that the one of the bolts that hold down the spring plate on the passenger side (D60) was loose. I went to tighten them and found that both bolts had ripped the threads out of the housing. The U-bolt is the only thing holding the spring to the diff. Has anyone ran into this problem? What should i do? I also noticed that the top of the pin that goes through the spring pack is tweaked and not straight up and down. :1zhelp: :what: I think i may have bent something. I measured from the ground to the fender on both sides on the rear and there is a 2 inch difference.
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I don't know about the bent center pin, but I had to tap both axle housing holes as they were shot...
  3. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    I tried to tap them out but the bolt hole just strips. What size bolt are you using?
  4. noahrob
    Nov 26, 2005
    1,878
    Santa Barbara
    One had enough metal, the other is slightly larger...I can't rememeber the exact size, but I mean just a little bit smallr, like the next tap 1/64th inch bigger or whatever...
  5. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    I am thinking about drilling them out to 5/8 and getting some super dooper strength studs and welding them in to the housing...there for I wouldent have to worry about pulling the threads out of the hole....
  6. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    They should be 5/8" now. You'd have to go bigger yet. You could try using a 5/8" bit to clean out the threads and then tap for 11/16" bolts. The only concern I'd have is getting good enough threads to handle 150ft-lbs of torque that should be applied to them.
    Better check the torque on all of your u-bolts.
  7. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
    Happy Birthday, BTW!
  8. bbck5on37s
    Jan 3, 2007
    543
    Denver Colorado
    Thanks....What do tou think about welsing studs in the housing?
    My bolts are 9/16
