i need some torque numbers...
Discussion in 'The Garage' started by colbystephens, Mar 24, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so bust out your 6.2 manuals, b/c i lost mine!
    rear main cap?
    Oil pan bolts?
    flywheel-to-crankshaft bolts?
    pressure plate-to-flywheel bolts?
    bellhousing to engine block bolts?
    engine mount bolts?
    that should do it for now! thanks! :bow:
    i really gotta find my manual. :o
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    So you have to go throw me with this diesel crap. If it were gas i could tell you off the top of my head. Anything diesel will require me to get into a book. If you get back soon enough with the year i may be able to help you before i leave for dinner.
    Ok, 379 diesel engine.
    Main bolts = inner bolts 105-117, outer bolts 94-105 lbs.
    Flywheel bolts = 60 lbs.
    Pressure plate bolts if they are 3/8" would be 25 lbs.
    Bell to block = tight
    Engine mounts to block = tight
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    THANKS!!! sorry - '83
