I need some welding done on wheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by racercrazy, Jul 4, 2003.
  1. racercrazy
    racercrazy 1/2 ton status
    Dec 29, 2001
    145
    O\' Fallon, MO 63366
    When I ordered new wheels almost six years ago, they sent me one wheel that has a bad weld. I have never been able to use this wheel.
    /forums/images/graemlins/1zhelp.gifI want to know if someone out there can weld this aluminum wheel for me. I'll pay a small fee if needed and for shipping both ways. /forums/images/graemlins/thumb.gif
    4 pics of wheel without tire that needs welded /forums/images/graemlins/1zhelp.gif
    Weld wheel /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  2. tRustyK5
    Jul 23, 2000
    36,163
    1,360
    E-town baby!
    That should be easy enough to repair...it's just a bad 'tie-in'. Most any shop that does aluminum welding would be able to fix that. I gotta ask why you didn't return the wheel when it was new? That is a manufacturing defect...
    At any rate I would back cut on either side of the problem area with a carbide burr and then run a cover pass over the problem area no more than 3" long. Then dress the repair with a grinder. MIG should be fine, that's what was used originally anyways.
    Option 'B' would be to TIG weld over the bad spot...
    Either way would work.
    Rene
  3. racercrazy
    Dec 29, 2001
    145
    Thanks for the info /forums/images/graemlins/thumb.gif, but I do not have the resources to do what you explained.
    Can anyone out there do this for me? /forums/images/graemlins/1zhelp.gif
  4. nevercomplete
    nevercomplete 1/2 ton status
    Dec 25, 2001
    309
    Beaufort, South Carolina
    I'de help you out if I could. My welder is in South Carolina and I'm in Japan, sorry.
    Jon
  5. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    see anyone on 44" bogers in japan?
  6. nevercomplete
    Dec 25, 2001
    309
    They wouldn't fit on these tiny roads. I have seen some interesting stuff though. One Marine here has a real nice Land Cruiser on 38's. Saw a 3/4ton Suburban yesterday, first burb I've seen over here.
    Jon
  7. racercrazy
    Dec 29, 2001
    145
    Anyone else out there that can help me out? /forums/images/graemlins/thumb.gif
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Look up a welding shop in the phone book. A repair like that shouldn't run any more than $30, probably less.
    John
  9. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Does it leak air out of that weld? If not I would use it. You coule also clean the area up and use some cold weld to seal it. If the weld didnt hurt that structure you are okay.
    Dan
