I need something cleared up.....TBI related
Discussion in 'The Garage' started by Can Can, Apr 23, 2007.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I have read many different articles about setting minimum air on a TBI motor. I understand all the steps, but there is one little thing that I need cleared up.
    When you go through the procedure, you always start by grounding out the A and B pins. I have read several articles that state that the paper clip needs to be removed before starting the truck, however I just read another article tonight that DOESN'T mention removing the paper clip before turning the key.
    Which way is right? :dunno:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have always left it in place. Even though it goes against my gut feelings about shorting something out then applying power to it.........
  3. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    I think you may be confusing two different things, start and on positions.
    I leave the paperclip in and just turn the ignition on, NOT START, and read the codes.
    But before I engage the starter, I take the clip out, and start up the truck.
    Hope this helps.
  4. Can Can
    15,552
    136
    Yeah, that's what I was thinking. Like I said, several articles have warned against leaving the clip in place, and that's how I've always done it. It never dawned on me that you could just leave it in.......
    Any other feedback on this?
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    From what i've read on a TBI you cannot set minimum air as the ECM does this for you, but on a TPI you can set minimum air. :confused:
  6. Can Can
    15,552
    136
    Actually, Scott, my Chilton's manual shows a step-by-step on adjusting minimum air on a TBI. I've actually done it, and it works. :thumb:
  7. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm trying to look for where i read that it can't be done. If it can i need to know how because my rig idles too low but not all the time.
