i need to know
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by gangbox1, Jul 15, 2002.
  1. gangbox1
    gangbox1 Registered Member
    Jun 10, 2002
    37
    HIGH DESERT NM
    hello all, i was fooled!! the back seat on my 72 blazer isnt original. i am changing the carpet out and the seat has had holes drilled for it.there is 4 original (5/8 or 3/4) bolts that go in line between the fender wells. are they for the real seat? or for seat belts? how many bolts were used to bolt down the rear bench? replies are appreciated. thanks
  2. MikeH
    MikeH Registered Member
    Apr 5, 2001
    24
    Monument, CO. USA
    When I purchased both my '71 and '72, the rear bench was held by 4 bolts using the stock brackets. There were no provision (on mine anyway) for seat belts. I drilled six holes to install 3 sets on lap belts on both my blazers.
    Mike H
  3. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    I am pretty sure mine is an original seat. The two outside wholes ( 1/2``} between the fender wells hold the back of the seat down and it is held by two u-bolt things in the front. I don`t know what actually held the seat in the front . I herd my boss at work say that his brotherinlaw used to have a blazer like mine, and the seat was held in front by some kind of clamps. I just used little u- bolts on mine. I could be wrong on my seat being original though.
  4. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    On my '72 the outer two bolt holes you're talking about (nearest the fenderwells) hold the rear seat and the inner two are for the seat belts. The other end of the seat belts on mine bolt to the back of the seat, right above where they're attatched to the truck using the aforementioned holes. The front of the seat is held using brackets that look like electrical coduit hold down clamps (which work well I'm told).
    CT
  5. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    I'm pretty sure mine are original. The rear is held down by four brackets and 1/2" bolts. The seat belts are attached to the two center brackets. The front is held down with two of the conduit style clamps that Chris T mentioned.
  6. gangbox1
    Jun 10, 2002
    37
    HIGH DESERT NM
    thanks for all the info guys!!! it has cleared things up!now i need to find a original seat. oh well
  7. bUrLyBlAzEr89
    bUrLyBlAzEr89 Registered Member
    Jul 10, 2002
    47
    Nipomo, Ca
    gettin new carpet is always fun
