I need to lose an inch from my waist, but how?
Discussion in 'The Lounge' started by divorced, Apr 14, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    What's the fastest bestest easiest way to lose an inch from my waist without losing any weight/bulk/size anywhere else? I'm a 33 now and I need to get down to a 32.
  2. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    Its that last couple of pounds that are the hardest to loose. Starving yourself will work.
  3. divorced
    Jul 20, 2004
    5,115
    Well, actually I've been trying to gain weight. I started a year ago at 118 pounds with a 32" waist. Now I'm 165 pounds with a 33" waist. I'd like to gain another 20 to 30 pounds and get my waist back down to a 32.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Doing some heavy duty ab work and side bends with dumbbells will work fairly well. Although you can't spot-reduce fat by doing this, it will tone your abdominal muscles and in essence "pull up" the excess fat, thereby slimming your waist a little bit. What's with wanting to lose the inch? Don't wanna go buy new pants?:wink1: Congrats on achieving your goal of weight gain and still keeping close to the same size waist. Weight gain/loss is a very difficult thing to do if you are not pre-disposed with the metabolism you want to have. I'm still working on cutting down. I weighed a couple pounds shy of 240 last spring and now I'm at a fairly healthy 195, but still have a ways to go. Kudos to you for attaining what seems to be a healthy addition to your frame. :thumb: And good luck!
  5. divorced
    Jul 20, 2004
    5,115
    Congrats to you for your loss :thumb: I would have to guess it's a lot easier to gain than to lose, so at least it's fairly easy for me.
    My main reason for the 32" waist is the fitment of clothing as you guessed. My work uniforms come in 32" or 34". I don't wear belts, and I don't want to gain another inch of waistline, so I'll try to lose an inch. I also like the small waist/big top look. I'm 6' tall, and I think that about 190-200 pounds with a 32" waist would look good.
  6. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Liposuction :wink1:
    Quart of Jack Daniels, a Shop-vac and a metal brakeline should do ya! :haha:
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Is the Jack Daniels for the patient or surgeon?
  8. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I was assuming they where one in the same...
    Ya know, if you want something done right, ya gotta do it yourself!
  9. cbbr
    Jul 17, 2004
    14,681
    This may, just may, be carrying "built not bought" a bit far.:haha: :haha:
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    :haha:
    Talk about trimming your fenders... :eek1: :wink1:
  11. cbbr
    Jul 17, 2004
    14,681
    :haha: narrowed and boatailed.:haha:
  12. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    See, I knew CK5 wisdom could be applied to any daily activity!
    I've even learned how to create durable footwear with Herculiner, yet to not get it on my hootus... :bow:
  13. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    vegan.... and use lots of hi quality tofu protien
    and smart food combining
  14. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    :rolleyes: Vegan :rolleyes:
    OK, do you really want to know the best way? Most people don't.
    You burn the fat off.
    Any large calorie drop is risky, especially if it's hard for you to gain weight. You can drop fat without losing an ounce of muscle by doing cardio-vascular exercise. You just have to get your heart up to 125-140 bpm continually. Start with 20-30 minutes a session and work up to 45 at most. If you can, do it first thing in the morning, before you eat anything. If you can't make that work, you'll just have to go for longer.
    That 1" on the waist is going to be 4-5 lbs of bodyfat. 1lb is about 3500 calories. This tells you how much exercise you'll need. For example, if you burn 600 calories in a session, then you need to do like 23-29 sessions. In reality, it will less than that because you will cut back on the food *just a bit* and you will actually burn more calories all day because of the metabolism boost. So you're probably looking at 5 days a week for a month.
  15. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    "You Need Cortisol":p:
  16. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    quickest way? Get a sweat suit (plastic suit you wear) and work out or hit a sauna, you'll lose a few lbs of water weight and probably a inch off your waist, but it'll come back. when you re hydrate
  17. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    I've heard of people losing as much as 2" from their waste from one good colon cleansing session. Go get the poop out! hahaha
    What's your body fat %? As stated before, the only way to permenantly reduce the size of you waste is to reduce you body fat %. I am assuming that you have been weight training and incorporating an ab routine into your regiment, so more cardio is your answer as well as a possible adjustment to your diet. May need to reduce the carbs and/or sugar in you current diet.
  18. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    the raw pork diet.a tape worm works wonders for weight loss.just get the meds before it goes to far.:D
  19. divorced
    Jul 20, 2004
    5,115
    Yucky!
    My regiment includes eating irresponsibly as often as I want to. My job is very physically demanding and I stay fairly busy around the house/shop, so my body fat isn't too high. It's like an all-day exercise program.
    Here is what I just ate, and now I'll be going to sleep shortly (if I ever get tired).
  20. divorced
    Jul 20, 2004
    5,115
    I wish it would be Easter all year long. Peeps Bunnies ROCK!
