I never want to see another grinder again!!
Discussion in 'The Garage' started by 85mudblazin, Aug 30, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just spent 3 hours cussing, grinding, painting and only got 1 side of my D60 calipers ground :crazy:
    All well hope the big brakes are worth it :D
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    it'll be worth it in the end. its comin along
  3. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Imagine doing all that work and a caliper turning out to be no good. :doah:
    Your end result will be worth it I'd say.
  4. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    second one will be done faster since you have an idea of how much to take off for your wheels. ;)
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    First one took me three hours, second took me 45 minutes. Hang in there man, you've made great progress.
  6. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I am guessing you are useing a 4.5" grinder. I thought mine was one size fits all too, until i bought a 7" milwakee to use as a floor grinder in my business. but it sat around for a few days as i waited for the diamond cup wheel i ordered to come in, and so i decided to try it on metal (like it was really made for). Holy S**T that thing is a meat eater. it will take those big grind jobs and laugh at them. Seriously you coud be done in 10 minutes, just hope you got big arms, as it will give you a workout as well as your caliper. Kicks butt on axle housing shaving and general FAST material removal too. Ran me $169.00 IIRC, but sooo worth it on frustrating jobs like yours. :D
  7. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    BTW, where is your steering arm? going cross over, or is that a hydro mount on the tie rod?
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    No freakin way i would ever do that, and you can tell me all the "lotts of people have done it so it must be safe" stories you want.
  9. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I used to think that way too, until I pulled the brakes on my DD and realized half ton calipers are significantly weaker in stock form that d60's are ground.
  10. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    56
    Powell, Wy
    My first wheel took like an hour, second one was like 15-20 minutes.... with a 10" grinder. The first takes forever cause your always checking
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    when did you get a d60? it's welded?
    That must be the workout-look at ALL that grinding dust! Thats halarious-good work man
  12. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I agree with the others. Second is MUCH faster and easier because you know what it is going to take. Just be careful and don't over shoot.
  13. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    Hey now, are we talking about putting brakes from dana 60 axles onto the dana 44 axles? if so are the dana 60 brak calipers bigger and stronger? My stock calipers on my 1/2 ton 75 k5 vex me with their lack of stopping power, 'specially with the bigger tires.
    I will totally be in on this plan if that's the case!
    "Wrath, hate, pain and death
    The code we live by
    It's in our souls"
    ~amon amarth
  14. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    picture looks like a d60 caliper on a d60 axle, just ground to clear 15" wheels
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yep its a D60, you have to grind them to fit the 15" wheels.
    i think the second will go faster. I prolly spent a good 2 hours just painting them/testing/grinding. I went little by little till it didnt rub off the paint.
    There is no way these things are weak. They still have WAY more material then my old 10b calipers. I prolly removed about 3/16" in the thcikes of it and that was on the caliper bracket thats like 3/4" thick.
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea I have been hiding the D60 for awhile. :D got it about 2 weeks ago and have been working on it just about every day. I also got ANOTHER rear 14b with a detroit blah blah blah :D
    Ill start a new thread with the build up pics of it.
  17. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Going crososver, my Sky arm should be here thursday. Then the D60 is going in the truck then after I get this final caliper grinded.
