I put on my Furd towers today.... pretty easy
Discussion in 'The Garage' started by jjlaughner, May 17, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Pretty easy but it took alllll day. wow. Anyways I had to drill out the shock eye on the tower (7/16") and the frame for 1/2" bolts. I have a 1" body lift so I only had to do minor trimming of the inner fender lip to clear the towers. Everything went right on... which is a change for my installs, there's always a hangup.
    Anyhow I wired the shocks up so that they where at half height, mounted the lower section to the axle and then set the angle the tower would sit at with some welding magnets, then marked the back of the tower for the exisiting holes and the bottom of the frame. Drilled the holes and trimmed the bottoms off. Bolts slide right in and everything fit good. /forums/images/graemlins/waytogo.gif
    as always here the pics! /forums/images/graemlins/deal.gif
    [​IMG] [​IMG]
    OH, for a Daily Driver the gabrials seem very stiff (which is good), the azz end doesn't squat down at take offs (which helps with the vibes that I'm having), and other than forgeting to tighted the drivers side upper bolt before the test run all is well. Very happy with the $19.95 gabrials and the $20 shock towers /forums/images/graemlins/peace.gif
    I put the gabrials in the rear also... so the swap took right at $100
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Looks good. I think I need to get off my a$$ and put my towers on two. The wife has been complaining for a while cause the shocks are in the back seat of the car.
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I've had the shocks for 6 months and the towers for 4 months... I sold the shocks that where on the truck so I would HAVE TOO do the swap /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    another pic of the passengers side showing the angle of both shocks
  4. or2play
    Feb 22, 2002
    657
    Yuma, Arizona
    Mabey I should try that. Nah, I'd just drive around with no shocks. Not sure how long I've had them, but the numbers must be around yours.
  5. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I just did mine too. /forums/images/graemlins/thumb.gif I welded mine however as they could very well be subject to change. /forums/images/graemlins/yikes.gif
    Good luck to y'all in the future.
    Allan
  6. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    do you happen to have a part numbe on those gabrieal shocks that u used for the front....Jason
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    G63438
    yep what he said... I used them at all 4 corners
  9. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    do the shock towers come from a dealership (stock item?).
    also, how much extra travel do you think you gained? (was that a bds lift too?).
    i'm always so amazed how not rusty rigs are when you get outta the salt belt. /forums/images/graemlins/rolleyes.gif
  10. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    The Ford part #: E5TZ-18183-A
    You MIGHT find them at a dealership but you can get them from http://www.1stfordparts.com/ for $8.70 each.
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I got mine online froma dealer ship in Texas. Do a search for ford towers and there is a couple of tower posts with links.
    Also last fall when I done the BDS lift I took a flap wheel on the grinder, ground the frame completely down and painted the whole thing. As you can tell in a few sopts the rust is leaking back through. I might have to hit the heavy spots again.
  12. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    kinda dumb question but in the rear did you use the original shock mounts or did you put the towers in the rear to
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    original mounts, I could move the upper mount up 2" because I have the room, but this is my DD and occasional ramp whore /forums/images/graemlins/ignore.gif /forums/images/graemlins/whistling.gif
  14. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Yeah my local dealership sold them to me for $20CAD each.
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I paid about $35 a pair for mine by the time it was all said and done. If anyone wants the 2nd set I happen to have I'm willing to sell them for that price plus shipping, send me a PM.
  16. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    are the rear Bds shocks the same lenght as the gabriels??? can't really tell.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    From the looks of it, not only are they the same length, they ARE gabrials.
    Your shackle angle sucks. /forums/images/graemlins/rotfl.gif
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/rolleyes.gif Its a driver not a flex monster, I dont want to do a bunch of mods to this truck... yet. Thats what the other one is for. /forums/images/graemlins/deal.gif
    pretty much, maybe within a 1/2"
  19. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    do you know if the gabriels are the same lenght as the ranchos 90012'(i think the right number) at this point I rather go with gabriels for the price.
    thanks
  20. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I dont know they are close...
