I quit.
Discussion in 'The Lounge' started by Jagged, Mar 21, 2006.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Some people are just soooo stupid.
    My response:
    Umm back to basics. De-stroking is no "stronger" than the standard stroke, unless you upgrade to a forged crank, connecting rods, etc. in the process.
    Let's use SBC's for example.
    Starting out with a standard 350 SBC.
    4.000" Bore x 3.480" Stroke
    A "stroker" kit for the 350 is using a 400 SBC's crank. Which gives us a longer stroke (length the piston travels in the cylinder), yielding low-end torque.
    4.030" Bore x 3.750" Stroke orrr... 4.000" Bore by 3.800" Stroke ('00, "HT 383", Gen.I truck crate motor)
    Now, let's de-stroke the 350 with a crank from the 307 SBC. This gives us a shorter stroke, meaning the pistons travel less, which means we can wind up the motor faster. This gives up high-end HP, and with balancing can achieve RPM's well above what the 350 can do.
    4.000" Bore x 3.25" Stroke.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    welll
    acording to physics
    less rotating mass(de stroking) woould make the motor able to withstand highr RPM's wich would make it "stronger"
    he isent using the right words, but he has the right idea
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Doesn't really matter unless the motors are where they belong , stroker in a A-Body , revver in a Duece :thumb:
