i really need help with this
Discussion in 'The Garage' started by bigoltrux77, Dec 24, 2002.
  1. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    for the past 6 mmonths, my rocker arms have been nothing but problems. At first they got really loose and make my engine tick like a rolex, then they started to come so loosse theyd fall off and thats no good. I figured out that my rocker arm nuts suck so i got a set of posi lock nuts. What i need to know is whats the best to to readjust my rocker arms so i get the best performance with nock ticking? I have tried the TDC 90 degree way out of my Haynes manual but that did nothing, this is the only problem im haveing and would like to get it fixed. Thanks alot. Merry Christmas!!!Happy Hanukkah
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Pull a valve cover and loosen a valve yuntil it starts ticking, then tighten it until the ticking just goes away. Put another 1/2 turn on it, lock it down and move on to the next one. You can make the job A LOT cleaner if you install an old valve cover that has the top cut off and get the oil deflector clips from an auto parts store so the things don't squirt you. Without the clips and modified valve cover the job is really messy, oil will get everywhere.</font color>
  3. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    if you can't back them off till you get a tick and tighten them back about 1/2 turn then your lifter might be sticking. So if you've tryed and no luck then look at your lifters....
