I really need some help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stickshooter, Mar 2, 2002.
  1. stickshooter
    stickshooter Registered Member
    Oct 26, 2001
    23
    1981 K5 305 with stock HEI coil in cap ignition. I have fire on two cylinders only. New HEI coil, new ignition module, new plugs and wires. I've performed the ohmmeter tests on the ignition coil and the pickup coil, even though they're new and both checked out. I have 12v coming to the distributor. New rotor as well. I also ran a hot wire directly to the coil from the battery just in case my supply from the ignition was dropping out under a load.
    I did just notice that my gas gauge, instead of reading the 1/4 tank that it has been, is now way over on the right hand side in about the 4 o'clock position. I don't know if that has any thing to do with it or if it's indicating a short somewhere that's affecting the whole system.
    What's going on?
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Did you replace the cap and rotor too? The gas gauge thing sounds suspisious to me... Is the ground strap that attaches on the passenger-rear side on the engine still connected and in good condition? Finally, maybe you got a defective ignition module? Just a few ideas...
    Good luck... [​IMG]
    <font color=red>GOT MUD???</font color=red>
    <a target="_blank" href=http://home.attbi.com/~netwrite>Midwest Caravan</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I'm sorry, but is the pickup coil new or did it just test good? It is possible for the coil's resistance to test okay but still be bad....
    Mike
    The jeep eater ......[​IMG]
  4. stickshooter
    Oct 26, 2001
    23
    I did not replace the cap or the pickup coil. I did see what looked like a loose ground wire while I was tracing harnesses down checking for loose connections.
  5. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Definitely check your ground wires, a bad groud will cause all kinds of weird problems.
    87 V1500 305 TBI 208/465 4" 35"procomp mt Dana 44/12 bolt
