I saw something scarry
Discussion in 'The Lounge' started by BIG*RED, Feb 1, 2006.
  1. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    I was out running some errands and pulled into a parking lot, and as i did i noticed a Jimmy. and it was lifted. as i passed by it i saw that it didn't have blocks in the rear. So i thought must have a shackle flip or just lift springs.
    I parked the Blazer and walked over to it, and sure enough it had a shackle flip..but a scarry shackle flip.
    They were useing the stock shackle bracket!..they just cut a hole in the bottom of it, then shoved the shackle back up through it! I looked closer at it, and boy that looks pretty scarry. looks to me like the whole shackle bracket has been weakend buy cutting that hole in the bottom of it.
    I guess it works tho, but i sure wouldn't trust it:doah:
  2. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That was/is a fairly common practice to do it cheap, gusseting is your friend thou.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    common (as the article shows). its really not scary. Granted I prefer the idea of strengthening the bracket, but as long as you keep the cutting or just what you need for shackle clerance, its plenty strong.
  5. BIG*RED
    Mar 14, 2003
    1,094
    Yep. looked just like that. Guess i have been living in a cave, I have never seen a shackle flipped like that before. Still not sure that i would do that...at least not with out the gussetting...
    Does doing it that way still give you 4inches of lift? The Jimmy I saw sat lower than mine, but he also had smaller tires, so i'm not sure of the total lift it had
  6. josh86k10
    Feb 13, 2005
    423
    Knoxville, TN
    Don't feel bad, I wouldn't do it either. Although i have friends that have had good luck with this technique, I'm still scared of it.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i dont like it. you cant get a good shackle angle and you certainly cant get enough shackle swing. if your looking for cheap i guess it works. it doesnt perform though, and i cant speak for everyone but id rather spend a little to have a quality system then just skimp and get by.
