I saw the35 spline...
Discussion in 'The Garage' started by unclematty, May 12, 2004.
  1. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    dana44 ARB air locker, air lockers suck doodoo. that being said would anyone else be interested in a dana 44 spool that accepted 1 1/2 inch 35spline shafts? I'm considering having a couple made just to see how they hold up. /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/thinking.gif
  2. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You'ld still have the little stub shafts that like to break. It'ld be cool for a rear axle I think.
  3. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    no, no,no the only part left d44 would be the thehousing itself, I'd go 35 spline stubs too that would solve the strength problems /forums/images/graemlins/thinking.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  4. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I think you would then have to deal with the ring gear and pinion. That would probably be the next thing to break. But the 35 spline stuff sure wouldn't hurt anything.
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i was under the impression that full size 35 spline stubs and the matching ujoint will not fit in the knuckle /forums/images/graemlins/confused.gif
  6. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Most people will use dana 60 outers and a dana 44 center section. Strength of a 60 with the clearance of a 44.
  7. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Sounds like a great way to blow a big wad on something that will be a nice paperweight someday! Go for it, and post pics when you do.
  8. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Just like running built 1/2 ton axles. /forums/images/graemlins/rolleyes.gif
