I searched but.....d44 ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shane74, Jan 21, 2003.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I must suck at the whole search thing. Here is my question. can I weld my front D44 in place of a locker till I have $$ for one??
  2. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    suuuureee, just be sure the steering gear on your truck is really strong, and that the frame near the steering box isnt cracked. you may also run into axel breakage. how big of a tire are you running?
  3. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I'm running 38's with a part time kit. The ONLY reason I would consider doing this is because I don't lock it in till I need it. Also, would I experience any more damage/breakage with it welded than with a locker?? I just want to understand is all.
  4. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    some thing like a lock right will release when you go around a corner, or an lsd will never "lock" but it will be more user friendly. i guess if it isnt a daily driver and you only plan to lock the hubs, dive in then un lock em. go for it, when the hube are undone, you wont notice it.
  5. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Hmmmm, thanks. Good points to ponder!
  6. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    If you mean just shifting in and out of 4 wheel, yes, you will notice a welded front end even in 2 wheel drive if the hubs are locked. Much more than with a locker, which, depending on who you talk to is unnoticeable when in 2 wheel.
  7. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I will be running the part time kit in the t-case and warn prem. hubs. In 2H I shouldn't "feel" anything with the hubs unlocked. I was wondering how it would affect the feel and steering with just the hubs locked in on the trail, snowpacked roads, etc.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you want to weld it, DON"T lock the hubs until you hit the dirt, and even then I would just lock one side till you get to the hard stuff.
    Steering will be a challenge and it will understeer a lot. I have to do a lot of 3 point turns for places others just easily glide through.
    Unlocked hubs you will never notice it though, so driving it on the streets should be fine.
