I searched..Now I'll ask about vibrations *Now with a pic*
Discussion in 'The Garage' started by Stickseler, May 13, 2003.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I searched..Now I\'ll ask about vibrations *Now with a pic*
    I finally finished putting on my lift and drove my truck to work today. It's got rough vibrations from 15-45 but not when you mash the gas only when steady or going up a hill. when you mash the gas it kinda feels like a seat massager. I've read the problems with the axle but I've got a CV shaft. It's got a light Vibe at around 65 but it had that before the lift. It's going in Fri for a front end alignment what should I have them check for?
    Heres the specs: 89 K-5 235k miles
    Stuff Done this month
    TCI 2.5" Lift (the old springs were stock so it sits about 3-4" taller)
    Zero Rates in back
    Greasable Bushings F/R (Torqued to 50 lbs)
    ORD Front shackle
    TCI SX8000 Shocks
    Most of this work was done this time last year about 5k miles ago
    Jasper 350
    Rebuilt 700r4
    Rebuilt 241 with SYE
    New CV shaft with the slip yolk about a foot up from the pinion (it lengthened about .5 - 1" with the lift")
    New Hubs, U-Joints, stub shafts
    1" body lift, poly mounts, Pro-Comp A/T 33/12.5/15 new around Thanksgiving
    Also do I need to worry about my front drive-shaft length with the lift. and are they rebuild-able it feels a little loose at the spline?
    Also Thanks to: Rene, Bubba, Jeff and Evan for the help Definatly worth the $25.00 and then some /forums/images/graemlins/grin.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: I searched..Now I\'ll ask about vibrations
    <font color="green"> If the vibe goes away when you mash the gas, I'd guess that your pinion is aimed a bit too low. What's the angle like at the pinion/driveshaft u-joint?
    You'll probably need to get the front shaft lengthened, when you do the guy will be able to tell you if it's worn out... There is usually a little play but it shouldn't be that bad.</font>
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What rear axle are you running? When I installed my 14bff (truck has 2.5" lift) I got vibs from 45-65mph. Raising my transfer case back to the stock position (lowered after lifting) actually took my vibs out. My vibs were when I got off the gas or was at a steady throttle.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I helped ya????? Holy cow!!!!!!! Must not remembered it. /forums/images/graemlins/grin.gif
    Can't really help ya on the vibration after lift; but all the vibrations I've had has come from u-joints, bad rear ends, tires being out of balanced and also tread separating.
  5. TNS10HYBRID
    TNS10HYBRID Registered Member
    May 4, 2003
    21
    Hey, if you get up under the truck and twist each joint manually(is that a word?)both driveshaft ends and the joint between the inner and outer axle in the front end and then lift your front axle up and try to shake the tires from top to bottom to check for bad ball joints you will probably find the problem yourself. Good luck. /forums/images/graemlins/tongue.gif
  6. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    [/ QUOTE ] I'll check that. I didn't lower the T-case How do I measure the angle? I heard its suppose to be within 1 or 2 deg? /forums/images/graemlins/confused.gif
    What rear axle are you running....Raising my transfer case back to the stock position (lowered after lifting)
    10 Bolt...maybe I should Lower the T-case... /forums/images/graemlins/confused.gif
    Moral support....I had some ? that you answered....don't remember what though /forums/images/graemlins/grin.gif
    Did that...Also New ball joints last year ...yep manually is a word..and spelled correctly too /forums/images/graemlins/thumb.gif
  7. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> With a CV shaft you want the pinion to be just low of being right in line with the driveshaft. 1-2 degrees low is about right, but you can eyball it, if it appears to be damn close to inline, almost imperceptibly low, then it's about right. To do it right you need to get an angle gauge.</font>
  8. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Here ya go... Pics My wife thinks I'm nucking futs a midnight /forums/images/graemlins/grin.gif. Also are the u-bolts suppose to lean forwards about 5 deg? The axle sits on the springs OK /forums/images/graemlins/confused.gif
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    So does your driveshaft leak from where it connects to teh tcase? cause i bought a cv and it leaks because tehre is a plate loose in there and it leaves the same rtv stain on my undercarriage whenever i drive....
  10. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Now that you mention it..I was wondering what that was.. I was gona investagate this weekend
  11. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    Re: I searched..Now I\'ll ask about vibrations *Now with a pic*
    Try disconnecting the TCC connector on the tranny and see if that solves it. I just got a mad vibration like a week ago from about 35-45 mph under low throttle. I disconnected the TCC and it stopped vibrating, well goodbye lockup /forums/images/graemlins/smile.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yep, that pinion is a bit low. Do you have shims in the back right now? I'd guesstimate that you need it about 4-5 degrees up from where it is now, maybe a little bit more. </font>
  13. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I agree. You need to start with raising the pinion angle. Pull the rear shaft and put it in 4wd and take it for a spin. I would almost most of the vibes will be gone.
  14. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have to agree with Shaggy &amp; Wayne about the angle, but also, you might want to check the cv joint. When I first put my cv shaft in, the cv went bad after about three weeks, felt like you were sitting on a big bumble bee. /forums/images/graemlins/grin.gif
