I started my first rebuilt engine today! (6.2 Diesel)
Discussion in 'The Garage' started by colbystephens, Apr 1, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    oh man - what a freakin amazing day. i've been trying to start the 6.2 i rebuilt all this week. it's been rather frustrating because it was pretty slow moving to work out all the bugs and it happens that i have to drive about an hour to go work on my project (read: Expensive!). But, i finished my truck (or as finished as a CK5 rig can be) and i drove it. still have some bugs to work out before i'm comfortable driving it on the streets tho. here's a few pics to wet your appetite before i get the real media stuff up some other time.
    i have some questions tho. it runs kinda rough. some factors which i think will change this roughness over time is that it's got some really old fuel mixed with close to 10 gallons of good new fuel (i tried to siphon the old fuel out, but couldn't get anything into the tank), and being that it's a 6.2, i have to have it timed at the dealer sometime this week. what are the chances that as these two things are fixed it will run a bit smoother?
    when i first started it, i had a really bad leak from one of my fuel injectors. i fixed that, but i noticed a really bad drip of fuel which was coming off of the starter (which happens to be under the injector that was leaking). i don't think that it's fuel which is just dripping from that injector leak tho, because the fuel didn't stop dripping until i had shut down the engine. where could it be coming from? i've been racking my mind trying to think where that leak might be, but there's not many fuel lines above the starter, and those which i could see were not leaking. I haven't checked the secondary fuel filter which sits in the back of the engine valley tho. anyone have any thoughts?
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yaahoooo. Come on down to the Blazer-Fest July 19-23.[​IMG]
  3. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    WOWWWWWW, I know the feeling when u start a freshly rebuilt engine, though u look a little gunshy behind the wheel...
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    From the smoke I would say the time is way to retarded. If the injector pump is the same one that was on the truck, just line up the mark on top of the pump to the one on the front cover; make sure to do this while the engine is off.
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that timing is correct. the other timing still needs to be taken care of. i think the smoke is partly due to the terrible fuel i have in it.
  6. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Other timing? The only timing you can adjust is at the IP, and you can try advancing it just a hair. Loosen the three nuts holding the IP tight and rotate it so the IP line is one line width past the timing cover line (less than 1/16"). Rotate the IP towards the drivers fender. Fire it up again after snugging the nuts down. It should be smoking a lot less and will prolly be 'louder'. I had mine a little too advanced the first time I adjusted it and it was as loud as a Cummins at idle...but backing it off 1/16" fixed that.
    Fuel leaks are a pain, and old injectors do often leak. the return lines between injectors often leak too.
    I'd let it warm up so that it comes off the cold idle advance and see how the smoke is then. You may just be going through some crapola fuel like you said.
    Rene
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Did you install new copper gaskets when the injectors went back in?
    Rene
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    no, i didn't do the copper gaskets. i know i'm supposed to - perhaps i'll take care of that once i get my truck home. the smoke was just on the 3-4 start ups. i just like the look of the smoke, so i posted the pic. the "other timing" i'm referring to, i can't remember the name of it, but the hayne's manual says that there's the static timing, like you describe, rene, and theres timing which i have to take to the dealer to have them fix (special tools, etc.).
  9. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    New injector gaskets are a must, you'll be bleeding compression out without them. They're single use items and not spendy at all...
    Less compression isn't going to help starting or smoke.
    As for timing I know it can be dialed in using a luminosity probe, but the adjusting they are doing is still just rotating the IP. I wouldn't consider it vital to take it in, I never did.
    Rene
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    interesting. thanks!
  11. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    It's good you're getting help from the seasoned smokers. I've been quiet, I wouldn't even know how to start a diesel.:D
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Once you get your head wrapped around them they're much easier to deal with than a gas engine...
    BTW Colby, I forgot to say congratulations on the rebuild and getting it started!! :bow: It's gotta feel pretty cool when an engine you built fires up for the first time.
    Rene
  14. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Actually its more like "%*@#&!*$# I'm awesome! Let's drive to the Arctic, right now!:haha:
  15. diesel4me
    Jul 24, 2003
    17,577
    943
    Massachussetts
    So..what DID you do ???
    What was it that finally made it start?...airbound fuel lines??..:confused: ..weak batteries??:confused: ....it took a few blasts of starting fluid to get my 6.2 to fire up,after sitting 2 years,and me bleeding the fuel lines for 2 days!..
    I hated to use ether,but I was about ready to burn it if it didn't start by then,and didn't care if it hurt it!...:rolleyes: ..I guess it knew I'd reached that point!..its started up every time since,even after sitting for a month!..
    I'd get some "Howes Lubricator" ,"Diesel Kleen"or other fuel system cleaner/treatment into the fuel tank ASAP...it won't hurt,and might even smooth the idle out,and definately reduce the smoking...made a big difference in the way mine runs..:crazy:
  16. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    I'm glad you got it running :bow: . Fix those fuel leak's ! We don't need your rig to be catching on fire on the way home . We also don't need leaking fuel when we cut your fenders (sparks). I don't need your oil burner going up in flames in my driveway even though the fire dept is just up the road :haha: . I noticed you got mtr's on your rig . I just scored some used 35x12.5x15 of CL that I was going to run on the burb for street driving but they are way puny looking next to my 42" swamps . Get that thing up here so we can go wheel up at Goat Mt .
  17. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Glad you got it running! :D
  18. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    my old C10 had a leak by the fuel filter up on the fire wall that dripped diesel down onto the manifold, and down by the starter, maybe check the connections aroudn it.
  19. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ha! i brought my truck home today. feels pretty d@mn nice. i didn't have current registration, and i got a little run in with the police when i was at muddytazz's house, but they let me off the hook. then i snuck through the back roads to the ferry to get across the river and parked the truck at the inlaws house so that tomorrow i can get the missing steering component and get it smogged/registered! good stuff.
    the problems that kept me from starting it were the fact that i didn't bleed the fuel system right, so i didn't have any fuel, and the injection pump timing was wrong so i had to take the front of the engine apart to fix that. didn't consider that when i put the engine back together. :( oh well. i got it done! fixed the fuel leak too - it was coming from the injection pump where it connects to one of the lines. this solved the rough idle problem too - it runs soooooooo smooth now! man it's nice. kind of a bummer to have to take off the intake tho (on pre-84 6.2 trucks it's kind of a pain to take off the intake).
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Sometimes those guys stop ya cause they want to check-out your rig, I have a taillight bulb fix-it ticket right now from some old dude that "wheels in Glammis".:D
